RV.Net Open Roads Forum: is this worth buying for my honda 2000?
 > is this worth buying for my honda 2000?
bill h
el segundo
Posted: 11/07/07 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
hershey wrote:
The only real benefit to this plug is having more contact surface on the male side so that in itself would make it a plus for me.
Same here. We don't plug in, but we keep one for visitors who do. No more hot outlet.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
cabanaman
middleburg florida
Posted: 11/08/07 08:00am Link  |  Quote  |  Print  |  Notify Moderator
LeeT wrote:
k-bit wrote:
Isn't the orientation of the plug wrong to plug into a Honda --too lazy to walk out and look at mine.
Jack
The orientation? I don't have to look to know that you would never have a duplex outlet with both grounds toward each other or both grounds away from each other. This is standard configuration, there are no other configurations for 15A duplex outlets.
Yes it will work on hondas.I have seen other(cheaper)generators with the outlets ground posts pointing up so the adapter would not work.
Retired Navy
2007.5 Dodge Ram SLT sport 2500 quad cab 6.7 cummins,6 speed auto with exhaust brake.
2007 Open Road 378SA4S-5 quad slide.
B. C. S.
Boise ID.
Posted: 05/21/08 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone used this???
http://www.amazon.com/Dual-15-adapter-generator-convert/dp/B000H9UFV8
B.
2006 F350 SD/CC/LB Lariat 6.0 PSD
2002 Salem TT - T23LK
2006 Yamaha 2400is Generator
Mike R.
waterford michigan
Posted: 05/21/08 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have one, and on the back it says it is rated for 15 amps, and your honda has 20 amp outlets, so I would find a adaptor rated for 20 amps with the 20 amp male end.
1996 GMC Suburban 2500 2WD 1999 Saturn
1992 GMC Sierra CC 2WD 2003 Honda Shadow Ace
2001 829s Prowler Lynx
2005 KGE3500Ti Sinemaster
Reese Dual Cam
jhilley
Buxton, ND
Posted: 05/21/08 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Those prices on Amazon are rediculous. I bought one from my local RV store for $9.50. They are in the large catalog that most RV stores hand out. 15 amps is all you really get out of the Honda 2000.
Fisherman
Angus, Ontario, Canada
Posted: 05/21/08 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
cabanaman wrote:
LeeT wrote:
Jack
And pray tell why wouldn't the adapter work with the ground on the upper end?
