amberjax
Suffolk,VA.
What kind of brake controller does everyone recommend when towing the heavier 5th wheel toyhaulers?
STINGRAYRVMAN
PANAMA CITY
You'll have no complaints with a Prodigy by Tekonsha.
Arcamper
Fayetteville, AR
BrakeSmart is the best in my opinion and many more on here. Do some research and decide for yourself but I would never skimp on an item as important as your brake controller.
2007 Keystone Laredo 29RL 5th
2003 Ford F-250 SD Crew Cab 4x4 6.0 Diesel
Pullrite 16k Superglide with Super Rail kit
Brakesmart
StoneyPgh
New Kensington, PA Steeler Country
My preference is the Jordan 2020 Ultima. It utilizes a direct connection to the brake pedal arm via a flexible cable. No inertia devices and no delay in trailer braking.
Peter & Nancy --- We never had a bad day camping
'03 Silverado 2500HD LS XC SB 4X4 8.1L/Ally 3.73
Reese Pro Series 15K Kwik Slide Jordan 2020 Ultima
'08 Trail Cruiser TC527RL Rear Lounge V-Series 5er
dedmiston
Valencia
Moved from Toy Haulers.
rcchallenger
La Mirada, California
Depends what you want to spend. I use the Tekonsha Prodigy and am perfectly happy with the performance. I looked at Brakesmart but didn't want to spend the extra money.
Jordan Ultima has a very solid reputation too.
2005 Ford F350 XLT 4X4 SRW Powerstroke Diesel Firestone Air Bags
2006 Keystone Raptor 3612DS
2006 Yamaha WR450
2006 Yamaha YFZ450
2005 Yamaha TTR230
2006 Kinroad XT250CC Go-Kart
PrivatePilot
Courtice, Ontario, Canada
I picked up a Tekonsha Primus on eBay a few months back for only $45, brand new.
I've been very pleased with it - a major upgrade from an older inertial unit it replaced. I pulled a tri axle float (about 12500# loaded) a few weeks back an once it was dialed in it was excellent.
It uses the same technology as Tekonsha's high end controllers but without the auto orientation feature which keeps the cost down.
Great bang for the buck.
30' Keystone Cougar 5'er, Triple Bunkhouse, SuperSlide.
Chevy 3500 1 Ton long box crew cab dually
6.5 Turbo Diesel, 4.11 Rears, LSD
Miles towed in 2008: 12,900 Kilometers, 7990 Miles
Checkout my blogs, adventures, and more here!
Mark
Dieselgem
Pennsylvania
I am using a Tekonsha P3 which is the next generator of the Prodigy. It will tow either electric or electric over hydraulic brakes. It is not much more than the Prodigy and worth the difference.
P3 Brake Controller
08-KZ Escalade 41'CKS Escalade Pics
2008 F450 Super DutyTruck Pics
97 & 2003 FLSTS
2003 FLSTC (Wife's)
Sherr20
Copperas Cove, Tx
Brakesmart nothing better....not even the factory installed controllers. Had the Ford, Brakesmart is better.
2007 GMC 3500 CC Dually 4x4 Duramax/Alison, Brakesmart brake control, RDS 60 Gal AUX/Toolbox tank
2006 Grand Junction 35TMS, Sensabrake air/elec/hyd actuator, Kodiak Disc brakes, JT Strongarm stabalizers.
2006 VW Jetta TDI
1967 RS/SS Camaro
balvert
Windsor, Ontario
I have used the Voyager, Sentinal and Prodigy prior to the BrakeSmart. BrakeSmart wins hands down. It is so smooth, you don't even feel the trailer behind you. Your tow vehicle and trailer brakes are perfectly synchronized with each other. Given the price of my rig, the BrakeSmart was a steal.
Casey
Casey & Karen, Border Collies, Polly & Babe
04 Newmar Mountain Aire 34RDCK with tandem duals & XPS Ribs, Pullrite 25.5K Super 5th, MorRyde, Solar, RotoChoks
03 Dodge DRW Sport, Cummins, 4.10, 6 spd, MBRP SS Exhaust, Jacobs E-Brake, Tire Sentry, BrakeSmart
