RV.Net Open Roads Forum: Towing: Over Kill or what????
Search only in Towing
Open Roads Forum  >  Towing
 > Over Kill or what????
JayflightG2
Vancouver
Posted: 11/10/07 05:37pm Link  |  Print  |  Notify Moderator
Just curious on your guys thoughts on this.
TV - 2008 F350 SRW Diesel
TT - 2008 Jayco Jayflight G2 29FBS
I want to get the Reese 1,200 lb Strait-Line Weight Distribution Trunnion Bar Kit w/ Hitch Bar (Part Number:66084)
The sales guy thinks this might be over kill with the truck and TT.
What do you guys think or suggest.
2008 F350 Super Crew Lariat PSD
1200 lb Draw-Tite Trunnion WDH/DC
skipnchar
Topeka Kansas USA
Posted: 11/10/07 05:48pm Link  |  Print  |  Notify Moderator
Your RV dealer thinks you have too much truck to tow his trailer? Business must be good to risk a sale that way
Blaster Man
Much better to have too much truck than too little truck. Plus, when you want to upgrade your trailer, you'll already have the truck for it.
JayflightG2
Vancouver
Posted: 11/10/07 05:52pm Link  |  Print  |  Notify Moderator
Sorry, let me rephrase, he thinks the Reese straightline system is to much or not needed for this TV and TT.
Broccoli1
Los Angeles
Posted: 11/10/07 05:58pm Link  |  Print  |  Notify Moderator
Your Dealer may be correct as you want to Match the WD with the Actual Tongue Weights that the Trailer has.
.... what's is the Unloaded TW listed by the maufacturer?
06 F250 V10 SB 4x4 Gulp Gulp
WW FSC2800
Rincon 650, Rhino
Power Wheels 750
"Shoot, I'm the world's best backwards driver!"
KC0BID
Denver, CO
Posted: 11/10/07 06:00pm Link  |  Print  |  Notify Moderator
IMO overkill is not a bad thing wen you are talking about towing.
Crossroads Sunset Trail 30BH
Dodge Ram 1500 TV with dual exhaust and K&N cool air intake
2003 Polaris 600 Twin ATV
2006 SunL 110 ATV
1979 Honda Goldwing (riding restore)
JayflightG2
Vancouver
Posted: 11/10/07 06:02pm Link  |  Print  |  Notify Moderator
Dry weight is 690 but the lower level is 800 lbs bars but I know my tongue weight will be close to 1000 to 1100 lbs with propane, 2-4 batteries, 4 bikes etc.
skipnchar
Topeka Kansas USA
Posted: 11/10/07 06:07pm Link  |  Print  |  Notify Moderator
Your dealer is a strange one for certain. Towing a 30 foot trailer with no weight distribution hitch or anti sway system is just nuts.
For what it's worth; My trailer is listed as 650 lb. dry tongue weight but fully loaded is 1200 lb.
Good luck / Skip
* This post was edited 11/10/07 06:14pm by skipnchar *
BarneyS
S.E. Lower Michigan
Posted: 11/10/07 06:13pm Link  |  Print  |  Notify Moderator
I suspect that will probably be just about perfect for the trailer you are going to get. I also agree with Skip's comment.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
yardsale1
Orange County, California
Posted: 11/10/07 06:19pm Link  |  Print  |  Notify Moderator
I think what the OP wanted to know was if the 12K WD hitch was the right one, or if he should get a lesser rated one. I think the next one lower are the 10k ones. If the dealer says the 12K is overkill, go with the 10K. You can always weigh the thing after you load it up. If you are over on the 10K, you can just swap out the WD bars for the bigger ones. I believe the bars are the only difference between the two hitches.
2007 Keystone Raptor 299MP
