Perhaps I didn't post the original question in the right forum, it doesn't show up as a new thread. Anyway my question was why is there no mention of installing electric brakes on the back of a dinghy. One reply was that there was a system being developed that would work electronically to apply the brakes. The antilock brakes would be a problem but it should be possible. Any thoughts?
If you could design and build a brake system that would be sold for less than the current auxiliary brake systems on the market. It would be a good idea. Must be easy to install.
I do not think it can be done.
ronfisherman wrote: If you could design and build a brake system that would be sold for less than the current auxiliary brake systems on the market. It would be a good idea. Must be easy to install.
I don't think any vehicle manufacturer would allow it due to legal reasons.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam, Newmar DP Owners Group
51st yr of RV'ing
I was thinking an Electric Disc Brake attached between the Driveshaft and the differential ,sort of an Electric E Brake would work! It just needs to Help to Slow the vehicle and/or bring it to a Safe Slow stop in the event of a disconnect!
I'm thinking I might do a little Tinkering in My Next Workshop!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
