RV.Net Open Roads Forum: Actual federal weight law rules, some questions and answers
Search only in Tow Vehicles
 > Actual federal weight law rules, some questions and answers
Page of 15
wny_pat
Western NYS
Posted: 04/03/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Mike Up wrote:
While the public at large is protected from commercial overweight trucks, looks like none commercial or recreational vehicles can cause harm to anyone on the public roadways from overload conditions without any legal protections for the public.
How about this? 24 states require all registrants of commercial vehicles to obtain Federal DOT numbers. In some states, pick-up trucks are issued "Commercial" license plates. New York state is one of those states. The minute you register a pick-up in NYS for 10,000 lbs or more gross weight, they want you to apply for a Federal DOT Number. The minute you register with the FMCSA and put a DOT number on your pick-up, you fall under their regulations. If you do not have the DOT number and are ticketed for it you have to appear before the judge and prove that you are not required to have a DOT number. The following is from: http://www.fmcsa.dot.gov/registration-licensing/registration-USDOT.htm
"Some States Require USDOT Numbers
In select states (see green highlighted states or list below), all registrants of commercial motor vehicles, even intrastate and non-Motor Carrier registrants, are required to obtain a USDOT Number as a necessary condition for commercial vehicle registration.
(On their page there is a map showing the states that require this)
Alabama, Alaska, Arizona, Colorado, Florida, Georgia, Iowa, Kansas, Kentucky, Maine, Michigan, Minnesota, Missouri, New York, Ohio, Oklahoma, Oregon, South Dakota, Tennessee, Utah, Washington, West Virginia, Wisconsin, and Wyoming."
Voyager Mike
Hamilton, MT
Posted: 04/20/08 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Wadcutter wrote:
JIMNLIN wrote:
ok we've heard from a state dot officer [IL] on IL requirements,
I'm not and never was a "state dot officer". DOT is a completely different agency than the state police. DOT does not enforce weight laws, they do not do motor carrier inspections, nor do they have LE authority.
Truckers use DOT interchangeably with state police. 2 different agencies.
JIMNLIN wrote:
your rated weight [GCVWR] which is your data plate lists as your ratings, what your axles are rated for, what your tires/wheels are rated for...and dot loves to look at all of this
your "tagged" weight which is what you have declared your ratings to be for tagging.
Don't confuse registered weight with axle and gross weights. 2 competely separate things and one is not related to the other. The only thing in common between the 2 is the word "weight" but neither law is related to the other. It's confusing for those not familar with the law. When they hear/read the word "weight" they don't understand the difference between registered weight limits and axle/gross weight limits. The OP was inquirying about axle/gross limits.
I've explained registered weights ad nauseum in the past too. Registered weight limits are really nothing more than a tax. In fact if you look at your state statute for registration fees it's likely that particular statute is titled something like "registration tax fees". You pay a certain amount of tax, ie registration fee, to haul a certain amount of weight. For example, if you want to haul 8000 lbs in your pickup then you pay the tax (registration fee) for 8000 lbs. But if you then haul 11,000 lbs in your pickup you would be subject to fine for overweight on registration, ie, didn't pay enough tax to haul 11,000. We use to do force registration in IL where if someone as described in the example was stopped then we could force the driver to purchase higher registration plates right there before he was allowed to move further. The increased registration cost was in addition to the fine. Now we just write the citation and if there's a record of additional such violations, particularly if company owned, then inspections can be done on the company and force increased registration.
pupeperson wrote:
I wish you'd add to your comments the fact that equipment on our rigs that actually carry a DOT rating, like the tires and wheels, should not be loaded beyond those limits which actually are enforceable.
I didn't want to get into discussing motor carrier safety laws since they don't apply to the RVer. Commercial drivers should have received the MCS training. For a Troop to be certified to do MCS inspections is a 3 week class and involves a couple of very detailed tests. Weight laws aren't covered in that 3 weeks of MCS training as weight laws is a completely separate course that all Troops get in the academy. As a driver you know how extensive the MCS stuff gets. From front bumper to rear bumper and literally everything in between, including the driver and any passengers. When I was doing the full inspections it usually took about 45 minutes to do a complete inspection and that was if there wasn't any problems. I have done inspections where it took the entire shift to do the inspection on just 1 rig. If I were the drivers in those rigs I wouldn't have ever left the yard. Most of the time the drivers of those rigs were happy to help as they knew there were problems and had reported them but they were told to drive anyway or the company would get another driver. Find those kinds of things and the company gets a visit.
I am a commercial truck driver. And I have been pulled over for a weight check. Several times. And it was never by a Highway Patrolman. Always by a DOT inspector. They do not drive patrol cars. They drive pickups in this state, with some funky lights on top. And I would not dare mess with one of them. Laws may be pretty uniform from state to state, but apparently the method of enforcement varies.
Mike
10Ton
Posted: 05/02/08 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
I am not a LEO and will only speak of personal experience and my own opinion as to what I think to be correct.
Anyone can call the state DOT offices in any state as found on that states WEB site, although sometimes it is difficult to get through to a real live person to speak to that is actually qualified to answer your questions.
Texas allows one to register a pickup for whatever weight you are willing to pay the tax for, when using as a company vehicle hauling your own companies equipment(non-commercial), or if it is "for hire" or commercial use and in both cases the trailer has no weight applied to the registration (token trailer tag). Above 26,000# requires a DOT# as do most states. In the case of a private use pickup, it can only be registered for it's Fed label, and as Wadcutter indicates in IL, the RV trailer will have a registration fee for it's own weight rating. I believe Louisiana only allows you to register for the amount AS LISTED ON THE FED TAG reguardless of purpose(not recently verified). Each state will look at your plate and recognize the other's rules while you drive through, however, some states, like California and New York sometimes have additional rules. It's almost like going against the Fed regs, but I'm sure they will argue that they are just more strict and have added additional rules rather than ignoring Federal Regulations, as to what the states are allowed to enforce.
As to the troopers being referred to as DOT. In many states there are Troopers, and then the Troopers that enforce Weights and FMCSR regs. On the door of the vehicles they drive will usually have Department of Transportation, and other info. Most truckers call all of those types of troopers the "DOT" even if in some states that title is only used for the highway maintenance department.
Wadcutters other info is great, as well as the other LEO's however he is basing his info on IL regs and trying to convince all that the way IL does it regarding FMCSR regs applies nation wide. Not so. Also, as impeccable as his credentials are, the claims that all troopers or DOT officers will always be correct on the law is false. Doctors, Lawyers, Judges, and Carpenters all have made mistakes and do on a regular basis. Additionally some laws are either vague or misinterpreted. Otherwise, he has attempted to be very helpful to all in this discussion, and I'd put him up against any on IL regs and how they utilize the Fed regs.
Now, in case it hasn't been mentioned. The tire load rating is separate from the pounds per inch of tread width (or square inches of foot patch) which is usually generalized as axle weight, sort of like . . . the registered weight is only indicative of the amount piad to register, but is separate and different from the weight against the pavement, and possibly exceeding any other regulation. (one can be illegally over what they paid to haul when registering and be legal on Fed reg, tire load rate, axle load rate, GVWR, etc. And visa versa. One could register for a huge weight rating and be illegal on axle, or other limits, As Wadcutter has gone above and beyond to explain. Scale weight is relevant in both cases, but the fines are of totally different issues, different rules) Back to tire patch . . . there is a formula that includes tire diameter and width that determines it's foot patch size when at maximum rated inflation and with it's maximum rated load weight on board. This is how 20,000# maximum single axle weight is arrived upon as well as the entire 80,000 pounds limit, because anything beyond this applies more weight per square inch of pressure against the pavement and therefore more wear and tear on the highway as that vehicle travels along. Therefore, although undoubtedly this will never apply to an RV, big rigs pay for a permit for overweight transport for which the additional money will be paid to the road tax fund for maintaining our highways.
So, technically one could not be over the 20,000# axle weight but have narrow tires that are not rated for that amount. Texas DOT web site clearly state that a vehicle may not carry more that it's tires are rated for as seen in the last line at this address -- http://www.dot.state.tx.us/services/motor_carrier/weight_limits.htm
Wadcutter is correct in that most of the time RV'ers are rarely bothered. It is difficult to comply with all of the rules all of the time. Some states give little attention to RV's and others are a little more finicky, and have rules they simply have chosen to pay more attention to.
What I take from this entire string of post on this topic in order to be more prepared is . . .
1. Go to the scales and know your actual axle weights.
2. Check your tire rating.
3. Check to see if all states recognize your states style of registration as far as per max of Fed label rating, versus as per weight paid for at registration.
4. Be aware that you may need a written statement from your insurance company as to what reasons reguarding weight that they may deny covering an accident, and maybe more importantly, in what circumstances of weight overages will they guarantee to cover.
Others may add more items to check list in case I've left anything off, and remember, I reserve the right to be as wrong as anybody else.
Simply, food for thought.
Ken
jmramiller
Dallas
Posted: 05/03/08 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Ken,
I have a problem with the statement you make regarding an insurance company refusing to pay a claim. If an insurance company could refuse to pay a claim due to a violation then 90% of claims would not be paid. An insurance company could no more deny to pay a claim for being overweight than they could deny a claim for running a red light. Liability insurance would pay regardless of any action taken by the owner of the policy. lein holders would also be paid. I suppose they could refuse to pay beyond that but I seriously doubt it. Perhaps someone could post a link to an article or court case where insurance payment was denied due to actions of the insured.
It is my firm belief that if insurance companies were that concerned about what RVs weigh then we would all have to supply weight tags prior to receiving our policies.
I also am not sure what you mean by the Fed label. You stated that in Texas one could not register a truck for more than the Fed Label. If your use of the term Fed label applies to the manufactures sticker (GVWR/gawr) then your statement would be incorrect. My Texas registered truck is registered well above the sticker GVWR. If the term Fed label applies to something else then please explain. To my knowledge there is no other label on my truck.
2006 2500HD CC SB 4X4 Duramax/Allison
Prodigy/16K Reese/265E Tires/Bilstein Shocks
RM Active Suspension/RDS 60gal Toolbox combo
2008 Big Country 3490BHS by Heartland
Wadcutter
IL
Posted: 05/03/08 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
My response concerned the "expert" from OK referring to me specifically as a DOT officer. That's what I was specifically addressing. In IL, State Police is not DOT. DOT is a separate agency. I am very well familar with other states. I've worked with enforcement officers from almost every state and am aware of their authorities. I worked closely with and sat on several committees with FMCS and other states' MCS/weight units.
I never claimed such. What I did state, paraphrased, is truck drivers sure aren't the people to get legal advice from. If they were so well informed on the law then I and my brothers/sisters wouldn't have put so many out of service over the years and written so many tickets.
Actually the Federal Motor Carrier Safety laws have been adopted in toto by every state. The feds mandated it and every state has complied. FMCSR were written by the feds and every state adopted them. It was forced on the states. The reason for the forced adoption of FMCS laws was so the interstate driver will know when he goes from state to state he's got the same laws, be it driver requirements or vehicle safety regs. To say MCS laws aren't enforced the same in every state is not at all accurate. The reason the feds mandated FMCS laws on every state is specifically so the law is enforced the same in every state.
My other point has been that MCS laws are something the RVer doesn't have to worry about. The RVer running down the road with his 5er doesn't come under MCS laws. MCS laws are "motor carrier" safety laws. The guy in the 5er isn't a "motor carrier". Why some continually insist on quoting MCS laws shows they have no understanding of the topic. If they want to be covered by MCS laws then ask them if they carry a log book, an extra pair of glasses, extra batteries for their hearing aids, carry their medical card, etc.
I'm not sure what he's calling "fed label" is but the term "fed label" or "fed sticker" is as you described it, the label often found on the door posts.
* This post was edited 05/03/08 08:26pm by Wadcutter *
Camped in every state but Alaska
SOCADESERTRAT
Posted: 06/29/08 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
I am going to post this in the "Towing Forum"
* This post was edited 06/30/08 04:54pm by SOCADESERTRAT *
2001 GMC 2500HD SLT, 4X4, EC, Allison, 8.1L, 4.10 Posi, SB, 16x8 alloys, LT265/75Rx16E Goodyear Wrangler Silent Armor, Magnaflow SS Catback, Wester's PCM, Leer Tonneau, Westin Bars, Tekonsha Prodigy, Hensley Arrow
2005 Cedar Creek Silverback 33LFKBS TT
Willcamp4
Nevada
Posted: 07/17/08 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Being a retired LEO I have only one thing to say about this. The application of the standards listed in the original question deals only with the law as it applies to commercial vehicles. It does not apply ot those of us who drive our RVs on either local or interstate highways. Section 390 of the FMCSA deals with applicability and it states:
ยง390.3 General applicability.
(a) The rules in Subchapter B of this chapter are applicable to all employers, employees, and commercial motor vehicles, which transport property or passengers in interstate commerce.
It does not apply to us, but rather to the large commercial haulers. Of course that doesn't preclude some smart attorney trying to make it so. I have not read the entire thread to see where this wound up, but the law should be applied as intended.
Willcamp4
2000 Ford F-250 Super Duty, CC, Lariat, PSTD/Trans Craft Auto, Air Lift suspension, ATS turbo, DP 4 position chip.
Alpenlite Valhalla Limited Fifth Wheel, two Solar panels, four six-volt batteries, two Honda EU2000i generators
jmramiller
Dallas
Posted: 09/10/08 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
So every experienced LEO that has responded says that none of this applies to RVers. Everyone who still spouts this junk about GVWR and GAWR being legally binding and junk about RVers being hauled off to jail and being sued for being "overweight" should listen to the real experts.
As I see it about the only thing I need to worry about is my registered weight...not that I ever expect I will be weighed.
SolidAxleDurango
OK, USA
Posted: 09/10/08 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
jmramiller wrote:
So every experienced LEO that has responded says that none of this applies to RVers. Everyone who still spouts this junk about GVWR and GAWR being legally binding and junk about RVers being hauled off to jail and being sued for being "overweight" should listen to the real experts....
Now you're applying too much logic to it. If you continue to do so, you'll be hauled off and forced to camp in a Walmart parking lot. Slides and awning out, of course.
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 08 Weekend Warrior LE3505
Toys = 05 Kawasaki Prairie 360 4x4 ( x2 )
Ace!
So Oregon
Posted: 10/28/08 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Ken
That's not how insurance, or insurance companies work. Read your declarations page and policy booklet.
Page of 15
