RV.Net Open Roads Forum: Toy Haulers: onan 4000 surgs and dies
Search only in Toy Haulers
 > onan 4000 surgs and dies
OSCARDGROUCH
San Diego
Posted: 11/13/07 03:21pm Link  |  Print  |  Notify Moderator
Hi Folks,
About 6 months ago I bought a brand new fk1900 ragen xtra lite.
It has an onan 4000 that has started to act up, surges and dies.
I took it to the dealer and with out even looking at it they wanted to charge me 500.00 plus labor to replace the carb. 31 hours!!!! They
gave me a bunch of gruff about varnish in the carb but after the first 20 hours it has started to act up. Not covered under warranty.
any suggestios?
dedmiston
Valencia
Posted: 11/13/07 03:41pm Link  |  Print  |  Notify Moderator
Is that the dealer where you bought the trailer? I wouldn't take the gen there. Is there an Onan (or Cummins) service center near you? Contact them and see if they do Onan warranty service.
It's possible that it's a varnish problem (gas sat too long in the carb and went bad), but that's kind of rare in just six months. How often have you run the gen since you bought it? You're supposed to run it a half hour a month (I think) to prevent varnish in the carb.
You should add a fuel stabilizer (Stabil) to prevent the varnish. If you add this to your fuel station, then all of your toys will be protected too.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600 • Hooligan #3
Toys:
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
  • 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
Y-Guy
Tri-Cities, WA
Posted: 11/13/07 03:48pm Link  |  Print  |  Notify Moderator
I'd agree with Dave... contact Onan direct. Here is a link for their nearest service center.
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
Gale Hawkins
Murray, KY
Posted: 11/13/07 03:51pm Link  |  Print  |  Notify Moderator
Run some Sea Foam through the tank and carb intake. That will let you find out if it is varnish or not for $5.99. Add 2 oz per gallon (1 oz is normal but I have ran it 4 oz to a gallon) to the gas tank and pure from the can into the air intake. This is assuming it will run/restart after it dies. If it has one or more pistons and I own it then it gets Sea Foam. It has just been on the market for 70 years.
amberjax
Suffolk,VA.
Posted: 11/13/07 06:20pm Link  |  Print  |  Notify Moderator
Check the spark plug(s). I have an Onan home generator that had very few hrs. on it and was doing the same thing although it is natural gas powered. Cummins Atlantic fixed it after 3 or 4 tries and 3 months. We thought it was a fuel problem also but ended up being the plugs were wasted. I believe it had less than 25hrs. at the time. Been perfect ever since. Plugs aren't cheap though....at least for mine. Hope this helps!
wild bill
Mira Loma, Ca. USA
Posted: 11/13/07 08:59pm Link  |  Print  |  Notify Moderator
My 5500 developed a similar problem after an oil change.....I was able to talk to an independent Onan tech who offered the following advise...Find the spring on the carb linkage that is attached on one end to the carb and the other end to a small bar that has notches on it.....looks something like a short hack saw blade....Move the spring to the other end of the notches.....I did this and it fixed my problem.....you can move the spring back a few notches toward where it originally was and test for the same problem.
Hope this works for you?
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000,Sand Rail 02 Nightrain,ST4s KLR650,ll00RT,AOPA BMWMOA,EAA,HOG,TDR,NRA,FCSA
dedmiston
Valencia
Posted: 11/13/07 09:06pm Link  |  Print  |  Notify Moderator
Wild Bill brings up a good point...
Do you have the Altitude adjustment set correctly? It could be that it's worked fine for you at lower altitudes (beach camping, etc.) but doesn't work for you in the high desert. I leave mine set at 3,000 most of the time, but adjust it down if I'm boondocking at lower elevations.
amazongb
Highland CA
Posted: 11/14/07 12:14am Link  |  Print  |  Notify Moderator
Call Rage'n in Riverside, CA and take it to them directly. I'm sure they will take care of it with little hassle.
twinbubba
North Texas
Posted: 11/14/07 06:55am Link  |  Print  |  Notify Moderator
If your TH is only 6 mo. old there is no way your Onan shouldn't be under warrenty. I had a similar problem with my Onan 4000 after about 8 mo. I took my WW to a Camping World that was an Onan Service Center and they replaced the Onan fuel pump to solve my surging/dying problem. Haven't had a problem in the last two years.
TB
07.5 Silverado 2500HD Duramax Ext. Cab 4X4
06 WW FS2300
Polaris 330 ATP
Yamaha Vino 125
Wife Dana
Friend - Bubba
sin cal hd
Hooligan #109
Posted: 11/14/07 07:21pm Link  |  Print  |  Notify Moderator
My brother in law is jsut went through the same exact thing. The dealer covered. He added some fuel stabblelizer after they cleaned out the system. Runs fine now.
My Pics
05 2500HD Bowtie Duramax/Allison CC LT 4x4 6in lift
06 Rhino
07 Suzuki LTR 450 and of course
Wife and Baby Boy
