RV.Net Open Roads Forum: Travel Trailers: What Gears???
 > What Gears???
kearlms
Rexburg, ID
Posted: 11/16/07 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I would like to know what gears I have in my TV. It is a 1998 Dodge 1500, 4x4, club cab, 5.9 Lt 360. if you have any ideas or know the easiest way to find out I would love to hear.
dbbls
Missouri
Posted: 11/16/07 08:31am Link  |  Quote  |  Print  |  Notify Moderator
A dealer should be able to help by using the vin number. Another way would be to jack the rear end up and turn the rear wheel and count the rotations it takes to turn the drive shaft one revolution.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
b_salgado
Salisbury ,NC,USA
Posted: 11/16/07 08:50am Link  |  Quote  |  Print  |  Notify Moderator
There might also be a tag on the rear differential.
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
1jeep
acushnet ma.
Posted: 11/16/07 08:54am Link  |  Quote  |  Print  |  Notify Moderator
dodge 1/2 tons are either 3:55 or 3:92, some years had a tag in the glovebox. if not check the rear for a tag...the other would be to have the dealer look up the vin as someone said already.
2007 Toyota Tundra Sr5 DC 4x4 8'bed 5.7 tow package 4:30 gears
2007 Keystone Outback Sydney 32BHDS
2006 HD Street Glide
1997 Yamaha YZF1000r
1995 Honda CR500r
mooreadventures
North Carolina
Posted: 11/16/07 08:59am Link  |  Quote  |  Print  |  Notify Moderator
You can also do it the old fashion way - jack it up, mark the tire and the drivshaft at notable points. Turn the tire and count how many time the mark on the axle rotates past - stop turning the tire when you have returned to your maked point. The next part is a little bit of a guess, but if the mark ont eh axle is on the oppsite side of where it started, then that would be about 50% and if the mark rotated by a total of 3 complete times, then probably have a 3.55 rear end. If the mark stopped 3/4 if the way from the starting point, then you would have a 3.73. That how the axles are rated #.## for the axle rotation (3.73:1) and 1 for the tire rotation ... got the idea? You may not get it exact, but it would be close enough.
Mark & Tammy
'01 Excursion Limited, 4x4, V10, RoadMaster Active Suspension
'01 Prowler 31G
Equal-i-zer Hitch - Prodigy Brake Controller
sid hunt
arkansas
Posted: 11/28/07 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
should tell you on a tag on the rear end >>>if not write the numbers down and take them to any dealer of the brand of tv and they can tell you
dodge guy
Chicago, western subs.
Posted: 11/28/07 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, there will be a tag on the rear end cover bolt or on a tag in the glove box door. 3.55 was standard and the 3.90 was optional. if you ordered the off road pkg. you got the 4.10!
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
foneguy493
northeast ohio
Posted: 11/28/07 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
its in the glove box
take pictures.....leave bubbles.....lets go diving
places weve been
04 1500 ram 4x4
08 hornet 27b hideout
johntank
Oxford, Ms 38655 USA
Posted: 11/28/07 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with 3:55 or 3:92 the tag on rear axle will have either 3.5 or 3.9 stamped on it for the respective gear. I would br willing to bet a dollar to a donut that your gear ratio would be the 3:55's as they were the most popular gears and what most dealers ordered. JMHO
 > What Gears???
