RV.Net Open Roads Forum: Onan generator oil change - anyone done it
Search only in Toy Haulers
 > Onan generator oil change - anyone done it
firstturn
Anaheim Hills, CA
Posted: 11/19/07 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
According to my owner's manual, I should change the oil in the Onan (5.5 KW) in my 2007 WW FS2600 at the first 20 hours. I went under the trailer today and the oil filter seems easily accessible. Is changing the oil and filter on these as straight forward as it seems? I was quoted $90 by Giant RV to do the service but if I can do it myself I would just as soon do that. Oil filters are about $11. How much oil capacity do these have?
formertaterhead
Chandler, AZ
Posted: 11/19/07 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
It's very easy, less than 30 minutes. Depending on how your genny sits in your rig the drain port may not drip to the ground. I cut the top of a 1 gallon milk carton off and use the bottom to catch the oil. They hold two quarts.
08 Lariat F450 CC DRW 4X4 6.4L
07 Keystone Raptor 3612DS
05 Road King Custom
07 Can-Am DS 650 X
06 Can-Am DS 250
06 John Deere Buck
Strabo
Desert Dweller
Posted: 11/19/07 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
I vacume the oil out like on a boat, replace filter, add oil, no mess.
2005 Ford F150 SC FX4-Procomp 6" lift-Fabtec Lightbar-Magnaflow 3" CB-K&N C.A.I-Firestone Airbags-Prodigy-Overhead DVD
2003 24' Jayco Talon ZX TH
2007 Rhino 660 SS106-ITP-K&N-JetKit-T4-CDI-CVT-Grant-Holder LED LightBar
1992 CR 250
1995 KX 250
othertonka
Stockton, CA
Posted: 11/19/07 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, do the first change at 20 hrs. You might need a CUP type oil filter wrench that fits over the bottom of the filter and has a 3/8" square hole to use a 3/8" ratchet to get the filter off, as it is recessed and you can't get a hand grip on it. The oil drain should be the little Pet Cock valve right next to the fill opening and the oil drains out the bottom through a hose. Check in your Onan Manual for documentation and helpful tips, capacities, and grade of oil to use. Easy job that I would never pay $90.00 to have someone else do it. Although they will tell you that they do a complete check on the whole gen set for that price, if it is working all right what do you need to check at 20 Hrs of use? Read the Manual and go for it!!!
Onan 5500 Marquis Gold
* This post was edited 11/19/07 08:18pm by othertonka *
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Y-Guy
Tri-Cities, WA
Posted: 11/19/07 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
I've done all the oil changes on my Onan generators on two rigs. Very easy to do. As othertonka said the cup type oil wrench works ok, though sometimes I need to wrap duck tape around it for a better grip. I buy all the Onan parts at my dealer, filter and oil and takes me about 30 minutes.
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
R V Boy
Keizer, Oregon
Posted: 11/19/07 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I just changed the oil for the first time Saturday. WW FTL 4005 Onan 5500. Reading the above posts, I agree easy. Make sure you have the right filter tall slim one, and you will need the cap type wench, with a 3/8 drive.
2 quarts with filter, about $20.00. Gives you $70.00 to spend on some new toy for your rig.
revump
Las Vegas
Posted: 11/19/07 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
Easy, easy, easy - good luck and great travels.
Bob
Big_Gunz_
SoCal
Posted: 11/20/07 12:08am Link  |  Quote  |  Print  |  Notify Moderator
It's an easy job once you get the hang of it. What I did to help drain the oil was I got some clear hose, it's either 3/4 or 1 inch hose, and it fits nice and tight over the drain hose. After putting the clear hose over the drain hose, I put the over end in my oil pan. Turn the petcock and the oil drains down to the oil pan without dripping anywhere. Then you wait until you can't see any more oil in the clear hose and tighten up the petcock again. Change the filter, add two quarts of oil, and you're done.
2005 GMC Sierra 2500HD, Dmax/Allison, CC, long bed, 4X4.
2006 Thor Vortex 365WTB SS
www.DumontSandDunes.com
Strabo
Desert Dweller
Posted: 11/20/07 12:27am Link  |  Quote  |  Print  |  Notify Moderator
Dam, thats erotic...
Big Katuna
Deland, FL
Posted: 11/20/07 05:37am Link  |  Quote  |  Print  |  Notify Moderator
WIX makes the Onan filters. You can go to their website and cross reference to their equivelent and buy the at NAPA.
My Kharma ran over my Dogma.
