RV.Net Open Roads Forum: Dinghy Towing: Towing a 4-door Jeep
Search only in Dinghy Towing
 > Towing a 4-door Jeep
Hfx_Cdn
Nova Scotia
Posted: 11/20/07 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
When we had the Blue Ox hooked up to the Coach, they used a spare connector to connect to the battery. I'm not sure how they did it, but I was told that was part of their normal procedures, and that's why they preferred Blue Ox as it was equipped to make the connection. Having said that, our initial run with the toad won't come till mid December when we take it south.
Shepherd_lover
Left Coast USA
Posted: 11/20/07 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
If you run the BB off a 12v line from the coach, how is the breakaway going to work?
grimmwit
Eatonville, WA
Posted: 11/21/07 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
As mentioned earlier, the solution to your problem is to pull the IOD fuse in the fuse box. This will keep your battery from going dead, but still provide power to the right-hand side cigarette lighter.
I have an 07 JK that I towed for 2.5 weeks, and never had a problem with the battery.
An excellent discussion about towing the Jeep JK, along with a photo showing which fuse to pull can be found here:
http://irv2.infopop.cc/eve/forums/a/tpc/f/7586073452/m/3541098163
It's slick - the fuse is even designed to be pulled, yet remain in position in the fuse box. Piece of cake!
Hope this helps.
Grimmwit
LandL
Sun City Hilton Head, SC
Posted: 11/22/07 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for all of your comments. I reviewed the website you suggested and will follow the directions provided. They really cleared up all of my concerns. Really appreciate it. Happy Holidays!!!
[blue]Lou Ann & Larry[/blue] [blue]Sadie our Cocker[/blue][red] [blue]2003 Winnebago Brave 32V[/blue] [blue]2008 4-door Jeep Wrangler[/blue]
Note: Due to invalid formatting, all formatting has been ignored.
ky8t
Huntsville, TX
Posted: 05/07/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
I pulled the IOD fuse and still had a dead battery yesterday after a 14 hour run from Texas to Alabama. I even started the JK several times along the way, but when I got to the campground yesterday, it would not start. So out came the jump start battery.
Diggin wrote:
There is a fuse in the engine compartment that is very easily pulled that kills the majority of the system, but leaves the cigarette lighter live for the BB. From another board:
--kev
Lee, KY8T
2004 Itasca Suncruiser 33V
Huntsville, TX
grimmwit
Eatonville, WA
Posted: 05/14/08 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
--kev
I just towed my Jeep cross country over 5.5 days. I pulled the IOD fuse, and made it all the way across country without a problem. I did notice that if I turned the key too far, the dash lit up even with the fuse pulled. Perhaps you did that, and somehow there was more draw on the battery. Just a guess. If you figure out what happened, post it here.
Good luck going forward.
Grimmwit
