RV.Net Open Roads Forum: Tow Vehicles: Cummins 6.7 block heater
Search only in Tow Vehicles
 > Cummins 6.7 block heater
pep1977
california
Posted: 11/28/07 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
thanks all for the quick responses. a little more infor would be nic efor everyone, i live in california, but work has brought me up the the southeast corner of Montana for the winter. if i were staying home no problem as far as cold goes, but it is too cold up here. again thanks.
NavyDood
DFW
Posted: 11/28/07 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
If the Cummins dealer does not have it in stock, they will order it and then get ya for the shipping also. Napa has them too. When I bought mine from the dealer, it came in a Cummins box with a Mopar label on it. Go figure.
- 2004 2500 QC Short Bed, 4x4, 48re, Brite White, HOG 4" T-304 T-Back, Self made PSMBuick style intake, Isspro Pyro/Boost/Tranny Temp sittin on the dash
- 06 Pilgrim Legends 30RE2SLF-5 12,000lbs loaded
- B&W Hide-A-Ball w/5th wheel Companion
johntank
Oxford, Ms 38655 USA
Posted: 11/28/07 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Riddler6.7 wrote:
All 6.7's come with the Block heater installed. Depending on what state you bought it in and the options list is what determines if it came with a cord or not. Whether or not it was ordered with the option you have the block heater and at MOST have to purchase the cord. If you have to purchase it, you just plug it in to the block heater and you are ready to go! Do not let the dealer charge you $85
Depending on what state you bough it in and the options list is what determines if it came with a cord or not.This is not true as any dealer can order the truck with the block heater option $10 MSRP, both my 03 and now the 07 6.7 were ordered with this option.
Can anybody say this is not just a way some dealers make extra $$$ off a truck by not ordering it with the block heater option. JMHO
coolbreeze01
Redding, Ca
Posted: 11/28/07 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
johntank wrote:
Riddler6.7 wrote:
All 6.7's come with the Block heater installed. Whether or not it was ordered with the option you have the block heater and at MOST have to purchase the cord. If you have to purchase it, you just plug it in to the block heater and you are ready to go! Do not let the dealer charge you $85
.This is not true as any dealer can order the truck with the block heater option $10 MSRP, both my 03 and now the 07 6.7 were ordered with this option. JMHO
johntank is indeed correct.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
PaulandTammy
Elk Creek, Ky
Posted: 11/28/07 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
The later 5.9s and 6.7s are all built with the block heater from the Cummins factory. The Block heater option for $10.00 is only for the heater cord. I bought the cord from the dealer for $34.00 dollars and will install it myself. If I were to let the dealer install it then it would be (as quoted by the dealer) $85.00 which includes the minimum of 1 hour labor added to the cost of the cord. It seems stupid to pay an extra 10 bucks for a cord in order to use the block heater that was built into the block. It should be included in the Diesel package the way it used to be.
PaulandTammy
2006 D3500 4x4 Cummins 6 spd DRW
2009 Cardinal 362 BHLE
Riddler6.7
Arkansas
Posted: 11/29/07 10:53am Link  |  Quote  |  Print  |  Notify Moderator
he is correct that it is an option. BUT that option is not actually for the block heater, its for JUST the cord. My uncle bought a local truck that did not have the option and all he had to do was buy a cord and plug it in to the block heater that comes in all the trucks whether or not the option was chosen. SO as stated that option is not actually for the heater itself, just the cord!
Just like the early 07.5 6.7 cummins came with the exhaust brake but was not turned on or have the switch installed. SO they charged ppl like $500 to have it turned on via computer flash and for a switch. But ALL 6.7's indeed have the exhaust brake to begin with as it is just a bonus to having this kind of a Variable Geometry turbo.
2007 Dodge 2500 QC SWB
6.7CTD 6spd auto 4x4
2007 Ford F350 FX4 lariat Tow Boss
2006 Ford F250 V10 4x4
2001 Fleetwood wilderness 825 5X
2008 Polaris Sportsman 800 Touring - Stealth Black
2007 Can-am 800 - sold
2000 Polaris Sportsman 700
duggram
Chickaloon, Alaska and temporarily New Mexico
Posted: 12/07/07 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
minex, thanks for the diagram!!!
I just bought a cord in Deming, NM and they soaked me for $42!!!!
My truck also came with the smallest possible mirrors (on a dually with the tow package!?!). Needless to say I had to buy the regular tow mirrors after delivery and have the stealer (Lithia, Santa Fe, NM) install them.
duggram
Posted: 12/07/07 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Any suggestions on how to route the cable?
It seems a little long which makes me think I've got it routed wrong. There are also 3 of those plastic holders that you push in a hole to stablize the cable. They're already on the cable but I didn't see any where to plug them in. I can screw a cable strap to the bumper to hold the plug end, but I would like to know that it's routed right.
BTW I did route it around the oil filter and outside the frame to keep it away from the belt.
Any advice appreciated.
59022
MT
Posted: 12/07/07 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
A lil bit cold - snow doesn't last long here. This might help you get the cord:
Name & Address Certification Operating Hours
1. CUMMINS ROCKY MOUNTAIN, LLC
5151 MIDLAND ROAD, BILLINGS, MT 59101, United States
(406) 245-4194 Fax: (406) 245-7923
A1400/1700/2000/2300, B3.9/4.5/5.9, B5.9 GAS, C8.3, C8.3 GAS, ISB, ISB CM850, ISC, ISC CM850, ISL, ISL CM850, ISM, ISM CM870, ISX CM870, ISX CM871, ISX/SIGNATURE, K19, K38, L10 (ELECTRONIC), M11 (ELECTRONIC), N14 (ELECTRONIC), NH/NT 855, QSB4.5 CM850, QSB5.9-44, QSB6.7 CM850, QSC8.3, QSK19, QSK19 CM850 MCRS, QSL9, QSM11, QSX15 Sales Hours:
PARTS
07:00 - 19:00 MONDAY
07:00 - 19:00 TUESDAY
07:00 - 19:00 WEDNESDAY
07:00 - 19:00 THURSDAY
07:00 - 19:00 FRIDAY
08:00 - 04:30 SATURDAY
SERVICE
2. CUMMINS ROCKY MOUNTAIN, LLC
2700 HWY. 14 & 16 N, GILLETTE, WY 82716, United States
(307) 682-9611 Fax307) 682-8242
A1400/1700/2000/2300, B3.9/4.5/5.9, C8.3, C8.3 GAS, ISB, ISB CM850, ISC, ISC CM850, ISL, ISL CM850, ISM CM870, ISX CM870, ISX CM871, ISX/SIGNATURE, K19, K38, K50, L10 (ELECTRONIC), M11 (ELECTRONIC), N14 (ELECTRONIC), NH/NT 855, QSB4.5 CM850, QSB5.9-44, QSB6.7 CM850, QSC8.3, QSK19, QSK23, QSK45/60, QSK78, QSL9, QSM11, QST30 INDUSTRIAL, QSX15, V28 Sales Hours:
PARTS
07:00 - 07:00 MONDAY
07:00 - 07:00 TUESDAY
07:00 - 07:00 WEDNESDAY
07:00 - 07:00 THURSDAY
07:00 - 07:00 FRIDAY
07:00 - 07:00 SATURDAY
SERVICE
George
Lifelong tipi, wall tenter/mule packer. 850-ac in Montana.
61 U404, 99 Dodge V10, 79 Airstream www.nativeradio.com
NavyDood
DFW
Posted: 12/07/07 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
All the holes are in the truck frame.
