RV.Net Open Roads Forum: Truck Campers: Lance 1131 Battery Compartment
 > Lance 1131 Battery Compartment
Dave1131
Edmonton,AB
Posted: 11/29/07 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone tried to make the battery compartment bigger on the Lance 1131?
I would like to put two T-145's But they are 11 5/8ths tall. The Lance has 10 7/8ths Max with out the battery tray.
If anyone has tried I'd like to here how you did it?
Thanks
2001 GMC 3500, 8.1 liter,Firestone Air bags
Lance 1131
TSJA
Campbell,Ca
Posted: 11/29/07 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
How about 2 T-105 or 125's? I have 2 Lifeline 6V's, but I had to take out the sliding tray. When you get the compartment enlarged post some pics.
'07 Lance 1131
'04 Weldcraft Sabre
'06 F-550 PSD-4DR-4WD Rear air-ride and a Gear Vendor
Dave1131
Edmonton,AB
Posted: 03/19/08 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Well I finally did it!!!
I modified my battery compartment so it will fit Two T-145's
First step was cutting out the bottom of the battery box.
There was a piece of 1x1 aluminum I cut it out and built a 5 inch wide X 24 inch long X 1/4 inch thick bracket to support any material that was removed. This was installed under the camper and I didn't take a pic when I Had that area open
After I cut it ,I cleaned up the edges and gave the open area a coat of paint.
Next I had to make a battery tray
I kept it simple!
Then it was time to install the tray.
I spray foamed the under side and siliconed, for a water tight seal
The new toys
These batteries are rated at 530 minutes at a 25 amp draw. With my heater ,water pump, TV/DVD and a couple of lights going, My camper only draws 13 amps. This means I will get well over the 530 minutes.
If I ever have to drain them that far!
Here is a pic with the pro fill installed.
This will make battery maintenance easier.
LIKE A GLOVE!!
Now I just have to design a battery tie down.
This has added about 34 lbs from the two 27 series batteries I had before.
Have fun
Dave
46 Woodie
Elfin Forest, CA 92029
Posted: 03/19/08 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Looks good, can you tell me where you got the pro-fill battery accessory?
Thanks John
RevLeonidas
Oregon
Posted: 03/19/08 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
...wow! nice work.
...I have a lurking suspicion that Leonidas W. Smiley is a myth; that my friend never knew such a personage...
--Mark Twain
sutak
Harrowsmith, ON, Canada
Posted: 03/20/08 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Dave,
That was a great installation!
I happened to be in the local battery shop to get some rechargable batteries. There was the T145 that was visibly larger than the T105. I figured it must be better. What surprised me is that the T145 total AH rating was the same as T105. Well I didn't dwell on it too much until I saw your mods. Can you tell me why is the T145 better than the T105?
Larry.
I stand to be corrected. I checked the trojan website the AH rating is 15% higher than the T105.
* This post was edited 03/20/08 09:19am by sutak *
2001 Chev K3500 dually, LT, CC, 8.1L, Ally 1000
1998 Bigfoot 2500, 10.6
TSJA
Campbell,Ca
Posted: 03/20/08 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Looks good!
Dave1131
Edmonton,AB
Posted: 03/20/08 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
46 Woodie wrote:
Hi,
Thanks John
Hi John
I ordered it from CAMPING WORLD
Have fun
Dave
