RV.Net Open Roads Forum: Toy Haulers: Trailers for wide sand rails
Search only in Toy Haulers
 > Trailers for wide sand rails
dunedancers
Yucca Valley, CA
Posted: 11/29/07 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Class A RV and my Carson Hwy Cargo 20'x8.5' trailer won't easily accomodate the wide sand rail I just bought without using motorcycle ramps and skinny tires. I don't need all the fancy facilities of a toy hauler (wife said "We're NOT leaving the RV home!) but people keep telling me I need a toy hauler for the interior space.
Any suggestions?
Steve
GregsSD
Santa Rosa, CA.
Posted: 11/29/07 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Contact Sporttrailers in San Bernardino, They should be able to fix you up !
http://sporttrailersonline.com/Home_Page.php
2005 Ford F-250 4x4 Powerstroke Diesel
2002 Weekend Warrior FS2600
2006 Yamaha Raptor 700 SE
1987 Suzuki LT500 "Quadzilla"
2003 Kawasaki KFX700 Quad
Yamaha Warriors, Blaster, & Suzuki LT50
Kawasaki 550 & 650 Jetskis
Y-Guy
Tri-Cities, WA
Posted: 11/29/07 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Most of the time I see a sand rail hauled in any trailer they swap out the rear tires. Hauling on a flatbed is the norm. What are the measurements from the outside edge of wheel to wheel on the new rail?
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
y0manda
S. Corona, CA
Posted: 11/29/07 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
just use your carson trailer and have someone weld you up some ramps to keep your tires on the trailer duh!
2007 WW FSW2800 Billet Ed.
2005 F250, PS, Lariat, 4x4, 6" Fabtech lift, 35" Toyo Open Country M/T E Rated Tires, Fox shoxs, Indash GPS, DVD, 2 Cameras, Sirius
2007 Yamaha Raptor 50cc
2006 Honda CRF 450
2005 Honda CRF 50
2003 Suzuki GSXR 750
2007 BMW M5
dunedancers
Yucca Valley, CA
Posted: 11/29/07 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
It's complicated. The measurements depend upon which which tires are on the front and which are on the back. with sand tire on front 90" skinnies on back 80"  ( with paddles around 100")
with dirt tires on front 93" with dirt on rear 87". These aren't typos. The front tires are farther apart than the rears.
Right now, the process is dirt tires on back 87" & skinnies on front which is 84". The back tires barely clear the 87" that is between the cables supporting the drop down door/ramp. With this set up, I still have to ride motorcycle ramps up the wheel wells which have 82" between them. I've considered buying a 2nd set of skinnies for the rear and then back the rail onto the trailer, back wheels going between the wheel wells and stopping when the front tires hit the wheel wells. That would at least eliminate the need for ramps.
All the swapping of tires back and forth is a hassle. It gets even worse if, like me, you aren't comfortable leaving a $50,000 rail sitting outside overnight at Glamis. I don't have the garage space at home and need an enclosed trailer there. It's complicated.
I'll ck out the sporttrailersonline.com and keep reading here. There's a way to do it. Some are just easier and less expensive than others. We'll find it.
dunedancers
Yucca Valley, CA
Posted: 11/29/07 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
I take it the "duh" means it's a simple problem and any dummy could figure it out. Open your eyes, grasshopper.
ickman99
San Diego
Posted: 11/29/07 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Look on glamisdunes.com they always have trailers for sell and maybe they have a good suggestion for you.
2007 Weekend Warrior FS26
Strabo
Desert Dweller
Posted: 11/29/07 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
ToyHaulers are for hauling, er Toys, in a safe and protected enviroment, think of it as having your toys in the living room cause thats the largest room in the house....
2005 Ford F150 SC FX4-Procomp 6" lift-Fabtec Lightbar-Magnaflow 3" CB-K&N C.A.I-Firestone Airbags-Prodigy-Overhead DVD
2003 24' Jayco Talon ZX TH
2007 Rhino 660 SS106-ITP-K&N-JetKit-T4-CDI-CVT-Grant-Holder LED LightBar
1992 CR 250
1995 KX 250
Buggs
Cal City
Posted: 11/29/07 11:26pm Link  |  Quote  |  Print  |  Notify Moderator
The Trailrider 367 was designed to haul a sandcar. I don't have the exact specs but I know that Casey, the guy who designed it, basically designed something around his sandcar.
jdjanda
Austin TX
Posted: 11/30/07 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Most of the wide bodies are 96" inside, I haul a 4x4 that is 90" wide, takes careful placement but it fits.
