RV.Net Open Roads Forum: Toy Haulers: This otta bake your noodle!
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > This otta bake your noodle!
shadoow
South Texas
Posted: 12/03/07 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
here's some basic info:
here
KZ 33P Toyhauler
2008 GMC 2500HD D/A
2006 Ultraclassic
1978 FLH
2K5RKC
Midwest 50001
Posted: 12/04/07 12:43am Link  |  Quote  |  Print  |  Notify Moderator
bluedog1 wrote:
Not sure what the problem is, the other posts sound logical. But isn't there a gizmo that will prevent power from coming back to the truck from the trailer, but still allow power from the truck to go to the trailer? Would that not solve the problem?
Try this....Click
bkirkpatrick
Brea / Orange County, CA
Posted: 12/04/07 08:20am Link  |  Quote  |  Print  |  Notify Moderator
The problem is that most trucks have wires that are spliced into for all of the trailer functions. I do not believe that the "power" wire for the trailer is run directly from the battery back.
Raptor - Modifications
big buford
Buena Park, Ca
Posted: 12/04/07 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Operator Error Hope that helps
"My drinking Team has a racing problem"
04.5 GMC 2500HD D/A
04 WW FS30
Chenowth 4-seat Subaru pwr
02 Honda 400EX
86 Honda trx250r
Beautiful wife that's much nicer than me
GLM Racers
Ventura
Posted: 12/04/07 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Gary, you should look into installing a battery isolator, which is basically a one way switch that will only allow the current from your truck to pass to the TH battery, and block the current from the TH to pass to your truck.
Without this switch, and when you connect the TH to your truck, the battery circuit will be the sum of both TH & TV.
I also wouldn't trust the trucks current/voltage gauges, as they are not accurate; I would meaure the voltage with a volt meter instead.
Hope this helps.
bluedog1
SoCal
Posted: 12/04/07 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
2K5RKC wrote:
Try this....Click
knew there was a gizmo
2007.5 Chevy 2500 D/A CC Short Bed
2008 WW FSWL 32 Billet Edition
2008 700 Raptor EFI
2006 WR450 CA plated
2005 YZ125
2005 Polaris 90
2003 Kawasaki Lakota 300
1997 Jeep TJ (My Rhino)
1 wife, 2 kids a dog and 2 birds.
golfman
Sanger CA
Posted: 12/04/07 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
here
Interesting article. I came away with this: The voltage regulator monitors the voltage coming out of the alternator and, when it reaches a threshold of about 14.5 volts, the regulator reduces the current in the rotor to weaken the magnetic field. When the voltage drops below this threshold, the current to the rotor is increased.
And This: The voltage regulator controls the field current applied to the spinning rotor inside the alternator. When there is no current applied to the field, there is no voltage produced from the alternator. When voltage drops below 13.5 volts, the regulator will apply current to the field and the alternator will start charging. When the voltage exceeds 14.5 volts, the regulator will stop supplying voltage to the field and the alternator will stop charging. This is how voltage output from the alternator is regulated. Amperage or current is regulated by the state of charge of the battery. When the battery is weak, the electromotive force (voltage) is not strong enough to hold back the current from the alternator trying to recharge the battery. As the battery reaches a state of full charge, the electromotive force becomes strong enough to oppose the current flow from the alternator, the amperage output from the alternator will drop to close to zero, while the voltage will remain at 13.5 to 14.5. When more electrical power is used, the electromotive force will reduce and alternator amperage will increase. It is extremely important that when alternator efficiency is checked, both voltage and amperage outputs are checked. Each alternator has a rated amperage output depending on the electrical requirements of the vehicle.
This is what I was basically talking about. The regulator is sensing an incredible charge and therefore the alternator stops producing current until the bulk charge goes away. I am just surprised that more of you guys aren't experiencing this. I think it is more common than you think amung people who are using 6 volt batteries. I like the idea of an isolator as well. I was actually thinking of installing a dummy battery and connecting everything to it just for the trip, then connecting everything to the 6 volts when I get there.
2006 Vortex 277 Toyhauler, 2000 Chevy Crew Cab 454 One Ton long bed 2wheel drive.
2004 Polaris predator
2005 YFZ450 Special Edition
2006 Yamaha 700
2005 Yamaha Rhino SidexSide 4wd with locking diff.
2000 Honda XR200
2000 Honda XR250
golfman
Sanger CA
Posted: 12/04/07 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Hope this helps.
Thanx GLM and BTW we are going back to the dez right after Christmas and staying until New Years. If your not doing anything you should join us.
bkirkpatrick
Posted: 12/05/07 09:54am Link  |  Quote  |  Print  |  Notify Moderator
If this is an issue, I wonder why places that install the harnesses are not installing isolators also.
GLM Racers
Ventura
Posted: 12/05/07 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Hope this helps.
One other option Gary is to remove the TV battery supply from your trailer connector, which will isolate both TV & TH batteries.
Most all new TV have a 7-pin, which unlike a 9-pin does not have the battery supply for probably liability reasons.
Thanks Gary. As of now we're planning for OW with the Hooligans for New Years, but it all depends on my wife's schedule.
The Racers: Gilbert,Lisa,Matthew,Rex-blk Lab,Apollo-Yel Lab
08 Midnight Armour Rhino
03 F-250 PSD FX4 Crew Cab
O5 WW22FB
05 Raptor 660-Mom's
05 XR400
06 Raptor 350
06 CRF230
03 FX140 PWC
04 RXP PWC
93 Bahner Cruiser Boat
66 Sanger V-drive Race Boat
