RV.Net Open Roads Forum: Toy Haulers: Motorcycle Wheel Chocks
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > Motorcycle Wheel Chocks
gixxergreg
Marshall, MI
Posted: 12/17/07 08:36am Link  |  Quote  |  Print  |  Notify Moderator
baxley wheel chock, have the motorcycle sit on it instead of in it, much less stress on bolt downs also
http://www.baxleycompanies.com/Chocks.html
Chickie
Slatington,Pa USA
Posted: 12/17/07 10:17am Link  |  Quote  |  Print  |  Notify Moderator
For our trike we use a pingel that is removable. I can either drive the trike in or back it in. Just have to move the pingle. Also have 2 tracks on the floor. One on either side. In over 5000 mile the trike hasn't moved at all.
Good Sam Life member
GWRRA member
NRA Life member
2002 F350 Lariat SC 4x4 PSD 6 speed,
2008 Goldwing GL 1800/2008 CSC trike conversion
2008 KZ Sportsmen Sportster 35'
Retired and loving it.
LowRyter
OKC
Posted: 12/17/07 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Doc, good stuff. Very nice of you to share this. Since I don't have a drill press, I'll go to machine shop and have a dozen of bolts drlled & tapped.
I also went to Harbor Frieght today and got those chocks. For $39 each, it was a good deal. Let me ask dumb question #2. To tighten those chocks of the front wheel, I need to tighten the two nuts so that square keepers in piot bolts are snug in the square holes? I need to use a wrench each time I want to lock the bike in them?
The instructions with the chock aren't nearly so clear as your photos.
Photog101 wrote:
OK, here are the pics of how I set up my haul-master chocks. I have them set up so that I can have either one bike centered or off centered, depending on what else I am loading into the trailer. Or I can load two full dressed bikes side by side and neither is touching. Because of the front disc covers on the Goldwing, I set in plywood to raise the front tire 3/4" so that they do not get scratched.
I made my own floor mounts out of 5'8" bolts drilled and tapped to 3/8" USS, just off center, so that they can be aligned. For the hook tie downs, I drilled 3/4" bolts and tapped them with 1/2" USS for either threaded eye bolts or standard bolts.
I have used these type of tie down bolts for several previous trailers that I have set up. If I really need to have a flat floor, ti does not take that much to pull them out, or I can lay plywood over them.
"Doc"
Photog101
Garden City, Michigan
Posted: 12/17/07 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
LowRyter:
I sent you a PM. Once I adjusted the flip the way I liked it, I left them that way and secured the bolts and nuts with red lock-tite.
"Doc"
stimpy68
Posted: 12/18/07 08:44am Link  |  Quote  |  Print  |  Notify Moderator
I use an E-Trac system set up in my hauler. The tracks are through bolted to the frame underneath. I use a set of D-Rings with clips that I can set anywhere along the tracks in any position. I have pingle chocks that that lock into the track again in any position I choose. The chocks and D-rings are all removable, leaving just the tracks on the floor. I cover the tracks with a nice throw down carpet from wally world, that happens to match my decor, and we're all set with a nice floor to walk on.
I've used this set up to confiquire the trailer to haul anywhere from one to three Harleys at a time. It works great, IMHO
Smilodon
Titusville, FL
Posted: 12/18/07 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
The solutions previously mentioned (e-track, pingel, etc.) are all great. As an alternative, I bumped into a mention of the Bolt-it-on system (more info here) elsewhere on this site.
I ended up picking one up, and have been very satisfied with it. Here's a shot of it in my WW FB1900 getting ready to leave for a track day.
Smilodon
V V
LowRyter
OKC
Posted: 12/18/07 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
nice loooking track bike. With that ram air, am guessing it's a Yamaha.
Smilodon
Titusville, FL
Posted: 12/19/07 07:01am Link  |  Quote  |  Print  |  Notify Moderator
You pegged it. It's an antique, a '99 R6. I could probably draw a crowd at a track day now, explaining those weird things it has on it called "carburetors"!
I bought it as a lightly used (mostly stored) ex-racer to do track days on. Knock on wood, it still looks like the picture... So far.
Doing this stuff with a toyhauler makes it all the better!
whoowhoo
Paso Robles
Posted: 12/20/07 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
I use the Bolt-It-On set-up, by far, the best, easiest and quickest system (as a whole) available. When removed, nobody can figure out how I haul so many bikes. I am the first one loaded and the first one unloaded! First class product with first class people. Give it a look. Here is a picture of what is obtainable.
* This post was last edited 12/21/07 10:24am by an administrator/moderator *   View edit history
Smilodon
Titusville, FL
Posted: 12/21/07 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Hey! No fair, you've got more bikes than me...
