RV.Net Open Roads Forum: Class A Motorhomes: Sensor beeping in the rain
 > Sensor beeping in the rain
mscamping
any place, USA
Posted: 12/16/07 10:24am Link  |  Quote  |  Print  |  Notify Moderator
While going south this fall we got into rain and something started beeping under the dash, well it sounded like it was under the dash,but I think it was coming from the generator compartment, front center.. No warning lights and all gauges were normal.. Checked all fluids at the next stop, everything OK.. It must be a sensor that is getting wet and causing it to beep.. Any ideas?? Thanks for any help..
2003 Holiday Rambler Neptune 36 PBD 37' - ISB 300 Cummins w/Allison MH2000 5 speed
2005 Malibu Maxx w/Blue Ox Aventa II SMI Stay-n-Play Duo
FMCA - HRRVC - Chapters - 56,57,& 419 - Good Sam Life Member - C2C - Coach Net - full timers
Mike & Sharon
flhtci-rider
Montreal, Canada
Posted: 12/16/07 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Did your ABS light or ATC light come on? That happened to me and the d&&& buzzer would not shut up. One of the sensors got wet. How we found what one it was is we had some one in the coach with the engone running and in gear. The wheel by wheel we soaked it with a hose. Was the right front. Also if your water temp sender on the engine gets wet at the connection it will cause the same buzzer to go off. Some of that dialectric grease. (i think that is what it is called)on the contacts wil solve that. ( the grease that is non conductive)
2006 Scepter
2008 24' Haulmark EDGE
2008 Grand Vitara
My best friend DW
1 fur ball Max (AKA - PITA)
And enough solar power so I never have to start the Gen Set
jcarnevale
Newark,NY
Posted: 12/16/07 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2004 Diplomat which had the same problem.
Monaco in Elkhart and my local dealer worked on it several times. The problem is normally the oil sending unit on the engine. Monaco will tell you to seal the sensor with high temp silcone or undercar spray. Another problem area is the front air tank pressure sensor (if you have air brakes). I replace both sensors and it still beeped. Finally my local dealer and I decided to cut the alarm wire from the oil sending unit which was located in the steering boot. The newer Monaco's no longer have this warning sound installed.
Joe
jcarnevale
JALLEN4
OHIO
Posted: 12/16/07 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
I also had the same problem on an '04 Diplomat and it was fixed by sealing the oil sender sensor. Was a common Monaco problem for two or three years of production.
joelbaker
South Bay SF area, CA, USA
Posted: 12/16/07 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Likewise to Jallen4 and jcarnevale. Had the problem on our 2004 Knight. It was the oil sensor on the engine and was fixed by sealing with silicone. If you get the right person at Monaco they may be able to help. Several folks here had the problem and the fix with success.
Joel & Bonnie
3 teen boys and 3 dogs
2006 Monaco Diplomat 40PDQ w/4 slides, 40.5', Cummins ISL 400
Toad: 2001 Town & Country, Falcon All-Terrain, Roadmaster EvenBrake.
Rallies Attended: 8;Gatherings Attended: 3
MartyAndPeg
Jacksonville, FL 32204
Posted: 12/16/07 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, I will offer another idea. We had a similar situation last year. We were sitting at the time, and after a night of rain, we heard a whistling noise coming from somewhere under the dash near the brake/accelerator pedals. After poking around, I found the noise to be coming from the generator compartment. Our issue was actually a relay that had the plastic cover pop off a bit, allowing the contact to get wet. I popped out the relay and dried it off, put the cover back on, and it seemed fine. I called Tiffin to inquire about what i could expect if this relay was truly bad, and they just sent me a new one. I don't remember right now what the relay was for, but i could go check if anyone is iterested.
On Edit: Completed my thoughts.
* This post was edited 12/18/07 08:59am by MartyAndPeg *
Marty & Peg (and 2 cats)
2005 Tiffin Phaeton 40QDH/350HP Cat/MH3000
2007 Ford Ranger XLT 4x4/Brake Buddy
2007 Harley Davidson Softail Custom
Full-Timing-7 years and counting!
Looking for a purpose in life, try Habitat for Humanity RV-Care-A-Vanners!
Big_Eck
Cold Canada
Posted: 12/17/07 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
As above, the posters are correct, mine is a 04 and I was driving down towards the Keys a couple years back, and I heard this sound, I called my tech on my cell phone and explained in detail what was happening.
His question to me was " .....is it raining?....."
This has been a royal pain, once we drove for 3 days with it beeping loudly......
dielectic solves it...... for awhile.......
I am thinking also of snipping the alarm....
2004 Holiday Rambler Endeavour 40 foot 3 slides
10 year friend of Bill W
Driven over 200 New units of all kinds and descriptions
"...there are two types of rv'ers, those that camp and those that camp at a NASCAR race..."nascarcamping.com
mscamping
any place, USA
Posted: 12/18/07 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
You can hear the oil sensor in the back on the engine 37' away up in front going down the road??
This sounds like it is under the dash.. I don't think with my old ears that I could hear that..Thanks for your replies..
