GWnKIDS
Riverside
Creeker4life, It is my understanding that their are 4 bumps that stick up in the bed with the Reese.
Vulcaneer
Northern New England
My BIL bought a Superglide when he had a long bed originally. Didn't need it, but he knew when needing to upgraded his truck, he would be going to a crew cab, short bed. And he wanted to buy only one hitch to last for years.
FWIW...
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
Keystone Sprinter 33'9" 12,500 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
TajMahallin
Belgrade MT
We have the B&W. We pulled gooseneck with our first fiver, and now we have the hitch with the new one. DH loves it because he can pull the hitch out when he hunts or needs to haul something. It only takes him about 5-10 minutes to remove or put it back in the tow vehicle.
Hope this helps. Happy RVing!
Scott & Margo
Daughter (11)
Dusty (Aussie X) & Kadie (Cairn Terrier)
2006 Chev Silverado 3500 LT Quad Cab LB Duramax/Allison
2007 Cedar Creek 36RLTS Custom
"May you live as long as you want and may you never want as long as you live."
Our Webpage
fpresto
Maryland
I have the B&W with companion 5th. I love the fact that I have a gooseneck, 5th wheel and standard Ford receiver. I am ready to tow anything (within truck and hitch limts) and have a clean bed when not towing.
USN Retired
2007 Cedar Creek 30 RLSTS
2008 F350, DRW, V-10, B&W hitch,
Pressure Pro, JT Strongarms
NavyDood
DFW
My first question is how big of a 5vr you planning on pulling? The B&W is rated at 18K.
When I bought my truck it all ready had the B&W turnover gooseneck installed. It was a no brainer for me to go with the Companion even with my shortbed. My 5vr has a extended pinbox from Pilgrim. For everything I need and where I have towed and backed in so far, I have never come close to hitting my cab.
- 2004 2500 QC Short Bed, 4x4, 48re, Brite White, HOG 4" T-304 T-Back, Self made PSMBuick style intake, Isspro Pyro/Boost/Tranny Temp sittin on the dash
- 06 Pilgrim Legends 30RE2SLF-5 12,000lbs loaded
- B&W Hide-A-Ball w/5th wheel Companion
obscure person
Moore, OK 73160
I have the B&W in my truck and am most happy with ut. I can install and remove it without much trouble and don't need somebody to do it for me. I had a Reese 20K before and it was too heavy for this old man to handle. The B&W is one of the better investments I made for our RV activities.
22geno
Noble Ok
Will not coment on the Pullrite as I have not had any experiance with it but the B-W has been trouble free. I am 68 years old and can get it in an out myself buy pulling a couple of pins whitch will make it 2 piece an lite enough to handle by hand.
Geno
Gene"n"Betty 2003 G.M.C. 3500 S.L.T.ext cab dually duramax/allison
2009 33ft Crossroads Seville 3 slides. Just the Wife, me and Dusty a loud mouth Parrot.
JRMora
Now Located in Columbus, GA
Another B&W owner. Looked at both. The Pullrite is definitely a quality product, but for the money, I liked the B&W. I needed a clean bed, too (I build cabinetry and furniture as a hobby and didn't want to slide sheetgoods over the rails), and it really is a one man job to remove and replace the companion hitch. I store mine in my fiver's basement when not in use.
Juan
2004 Dodge Ram 3500 CTD/4X4/DRW/6 Speed
2005 Cedar Creek 36RLTS
Truck: B&W, Prodigy, Quadzilla, MBRP, Pac Brake PRXB
Trailer: Full Trail Air, Onan Marquis Gold 6500LP, Dual AC, King Bed
My RV Photos
Us: Juan/Lyn/Nick/Quino/Rico (3 Boys!)
Vulcaneer
JRMora wrote: I needed a clean bed, too (I build cabinetry and furniture as a hobby and didn't want to slide sheetgoods over the rails), and it really is a one man job to remove and replace the companion hitch.
My SuperGlide removal is also a one man job. Hook it up to the 5W, un pin it, and use front elevators of 5W to lift it out. SuperRails and all. Then move my table under it and lower it down and unhitch. Then just remove the 1/4 turn pins and the bed is clear. And roll the table into my garage. No manual lifting or sweat involved at all.
Built the table with wheels in an hour. Same height as Tailgate on my TV, so re-install only involves rolling the table to back of tailgate and sliding hitch back into position.
pamtnmn
Southeastern Pa.
I have a B&W now, was in the truck when I bought it. Old truck had a Pull-Rite, both are good, probably the two best. I suggest getting the one you feel most comfortable with and the best deal.
