RV.Net Open Roads Forum: Tech Issues: Replacing Sealand Toilet Seal
 > Replacing Sealand Toilet Seal
zipp
Centerville,Ohio 45459
Posted: 12/21/07 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Let me suggest this, when you take it apart lay the parts out EXACTLY the way they should be put back together. I know, because I didn't and it cost me more time trying to figure out why I couldn't get the clamp to fit around the bottom cover(the base). I can't remember, what I did, but it was a little thing. I'm not sure, it might have been, not putting the clamp on in exactly the same position. The nut you tighten or loosen is at the back and I think I tried to fudge it and have the nut more to the side, so it would be easer to get to. Well, anyway good luck and I hope it goes well for you!!
Denny & Mighty Wife
2002 Dolphin 5356
Towing 2004 Trailblazer
TravelSupreme
Grandview, TX
Posted: 12/21/07 09:54am Link  |  Quote  |  Print  |  Notify Moderator
What a great forum this is!! Thanks again and I will report back when the job is done.
orgelmo
Full timing it in the USA
Posted: 12/21/07 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I was going to replace my seals also, but when I called sealand they wanted to know why I just didn't clean them, when they were out. They also told me unless they were damaged, they would clean up.
They were correct, they cleaned up and are working well. Mine had a bad calsium build up on them, would suspect yours are the same, besides if it saves you $50.00.
Elmer
Elmer & Sharon
USN-(62-66)
Hacksaw, Congo Gray Parrot
Aries, Himalayan Pussy Cat
05-40 QDH Phaeton
05 Explorer Sport Trac
FMCA # 124188
Good Sam Life Member
TravelSupreme
Grandview, TX
Posted: 12/29/07 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Got my set of new seals yesterday and plan to put them in tomorrow. Will post with end results.
TravelSupreme
Grandview, TX
Posted: 12/30/07 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Did the job today and it holds water perfectly. Like everyone said, it wasn't terribly hard just a lot of work cleaning the calcium deposits off the ball and under the bowl. Thanks again for all the help.
Tcloud
Oak Hills Calif
Posted: 12/30/07 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks For the Update
Don and Barb
1999 Adventurer 275 Cummins Model 34V
franknsandy
USN-Retired, Skippers, Virginia
Posted: 12/31/07 10:43am Link  |  Quote  |  Print  |  Notify Moderator
I did mine twice.
The first time I didn't align everythin just right and it never would hold a water seal. The second time was perfect.
Yes, they get a build up of "stuff" and it can be cleaned off.
Interesting that the instructions said to use a non petrolium based silicon to coat the gaskets. It was hard to find, but found it at Camping World.
Glad you got yours done the first time.
Frank
Frank n Sandy
USN-Retired
96 Dolphin Diesel / 2002 Saturn
Fulltiming since 2004
TravelSupreme
Grandview, TX
Posted: 12/31/07 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, Frank. I sprayed some 303 protectant from Camping World on the seal and ball. I think that I will order another set of seals while I know where to get them and have them ready when the problem returns. I may even get a new ball assembly since it was the hardest to clean.
Richard
