RV.Net Open Roads Forum: Class C Motorhomes: Onan Generator - Will not Start
 > Onan Generator - Will not Start
abradf2519
Poughkeepsie N.Y.
Posted: 12/27/07 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Are you sure your battery is good? Usually clicking is a symtom of a bad or discharged battery/low voltage.
Alan and Marilyn; plus the kids: Daniel, Anna, Rebekah, Leah and Moriah
2004 Sunseeker LE 2900, Chevy chassis
B-Plus
New England
Posted: 12/27/07 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
JoyandCon,
This is a post the I submitted a few months ago with the same problem,hope it works for you.
Took my B+ for a trip to Lancaster PA, for the Holiday 7 days. Boy was it hot, but wouldn't you know, the generator would not start after I shut it down from the day before. I just would hear a clicking from the solenoid and a fault code of #32 telling me that I was not getting enough current to turn over the starter and to check all of battery connections. After I cleaned all of the connections ( something you really want to do in a parking lot)it still gave me the same fault code and would not start. Thankfully I had my laptop and was able to steal someone's unsecured Internet connection. I went onto the RV forum and did a search for ONAN and wouldn't you know I found someone else that has had the same problem. It seems that the piston stopped at TDC and there was nor enough punch from the 12V system to turn it over, the fix is to get a wrench onto the flywheel and get it off of TDC( Top Dead Center ) and it should start. That's all it was!!!! I had visions of having to come home and go to a ONAN dealer and hand over a few $$$$ for the repair. Not only that but having the RV tied up for days. I was also wondering , if that was all that it was, would a dealer tell me that and just turn the flywheel over and I would be on my way ? Or would I have had to pay the $100.00 deductible I have on my extended warranty and considered myself lucky? PS: Also love my new RT-170 but I will not be giving up my B+ anytime soon. After being in both for a while I love the added room in the B+ on a trip , and the RT-170 works out great as our daily driver and my solo trips up to Canada for fishing. Having to maintain two RV's may be a little bothersome in the future, but for now I find it very enjoyable. B-Plus
2003 6.0 Chev Trail-lite B-Plus 225
2007 6.0 Chev 170 Roadtrek ( Daily Driver )
1976 Corvette
JoyandCon
Franklin, WI
Posted: 12/27/07 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the suggestions. I was not able to get at the problem today. Will try this weekend.
I will try the easy suggestions, first.
If all fails, how do I get at the flywheel? Is it an easy task that can be done in the cold?
Thanks again all of you for the quick and concise responses.
Hope I can help in the future.
B-Plus
New England
Posted: 12/27/07 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
If you open the cover it's on the left hand side. You have to reach in with a 5/16 ? open end or a socket and just turn it a bit. Reach in with your hand and you can feel the flywheel and you will know what I am talking about. Yes it can be done in the cold, good luck!
BennieH
Johnson Creek, WI, USA
Posted: 12/29/07 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
To check for stuck at top center or a stuck bendix:
Remove the access cover and if you reach into the side left of the divider you will feel the flywheel.
I use a 3/8" drive ratchet with a short extension & a 9/16" socket (might be 1/2" - been a while) and put it on the bolt holding the flywheel. I give the flywheel about a half a turn once its free.
Starts right up after that.
Bob & Pam
2004 Coachmen Santara 31' 309KS
Nissan Frontier or Chevy Malibu Toad
Post your Park Reviews at:
http://www.rvparkreviews.com/
WhiteDog34
Fort Thomas, Kentucky
Posted: 12/29/07 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Mind did this a while back. It was corrosion at the negative connection to the frame.
Rick & Rox
2004 HR Atlantis 29PBD
Steer-Safe, Bilstenes
2000 Toyota Solara FROG
Remco Lube Pump, US Gear Unified Tow Brake
JoyandCon
Franklin, WI
Posted: 12/29/07 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Had a 6 inch snowfall last night 12/28. Will not be able to try the suggestions for a day or two.
Will let all of you know how I did.
Thanks to all of you.
parisroady
Livingston TX
Posted: 12/29/07 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
I almost thought I was reading about my own Onan 4000 prob with starter switch. Never a problem till it would not start and made a spinning sound when switch was pushed.
Finally went to Camping World told them it needed a starter and sure enough, it was fine after they installed one. $400 was the cost 2 hrs was the time. Hope you don't have to go that route.
JoyandCon
Franklin, WI
Posted: 01/02/08 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Went out to the motorhome yesterday, turned the flywheel (spins freely).
Took the battery out and charging it. Will clean all connections and reinstall. (High temperature today in the teens, this weekend will be in the mid 40's)
Will make sure all connections are tight.
Will report back.
Also, getting a BatteryMinder Plus.
dmatt
Ventura County, CA
Posted: 01/03/08 08:43am Link  |  Quote  |  Print  |  Notify Moderator
The same thing happened to me last week. All I got was a clicking. I tried starting it at the generator itself and same thing. Mine has a primer switch. After a couple of times holding the primer about 13-20 secs, it started right up.
2007 Four Winds Dutchmen 29R-Ford E-450 V-10 towing a 2008 Toyota Matrix XR
2007 Toyota 4Runner(V-8) towing a 2006 Reinell 220LSE, 5.0L, 280hp GXI
Our camping photos
under the stars
