gouficanuk
quebec city
if you tow the saturn on 4 turn the key to acc and cancelle all the accesories as well as the fog lamp
that is wat is writen in the manual 1996
question?does any one know how to cancelle the acc ??
wath about the trans will it stay neutral ??
thank you
lechouan
1996 american tradition
cummin 3 37ft
coming to florida on the 20/01/08
UsNtheBus
Calgary, Canada
I tow a 2005 Saturn Ion 3 Quad coupe. Once hooked up, I just turn the ignition switch to 'ACC' (not to 'ON' because that allows the headlights to turn on if it gets dark enough... as I learned when the battery was dead after towing through a rainstorm). Anyhow, I then make sure that the radio is switched off and the heater motor is switched off. I think what they mean by cancelling the accessories. I've never had an issue with the transmission not staying in neutral.
Have a great trip.
Graham & Elaine
"If you think you're old or you think you're young, you're right."
Currently: at home
2005 Coachmen Aurora 3480DS (Ford F53 V-10)
2005 Saturn Ion 3 Quad Coupe
Blue Ox Aladdin & BrakeBuddy
Our travel site
hwybnb
"Cancel" must be Canadian for "Turn Off".
In Pursuit of Adventure!
Darien, New York
We tow a 1997 Saturn wagon and do the same as the previous post -- turn key to acc and make sure radio and heat/AC are off, with car in neutral. We've never had a problem following this procedure.
Sue and Joe
2004 Fourwinds Windsport 35D
Saturn Wagon Toad
Two kids in college and
one spoiled Black Lab named Brodie!
Nascarcruzin
Home is where the RV is parked.
We tow a 1997 SL1 and do the same as In Pursuit.
Rebecca
Ronnie & Rebecca
Check out our journal: North to Alaska
Another website to view our trip to Alaska:
Adventure to Alaska
FMCA #388387
Full-time RVer's since 2004
Monaco LaPalma Workhorse chassis 37' 2-slides
erpa
South Central,East Coast. FL
Ditto to the above posts.
Eric & Pat
2002 Dolphin 5356
W22 Chassis
1999 Saturn SL1
2002 Trip FL to Alaska & back to FL Photos Link below
http://community.webshots.com/user/erpafl1020
Other Trip Pictures;
http://s125.photobucket.com/albums/p80/erpafl1020/
kalynzoo
Los Angeles , California
I tow the 05 Vue. Key to ACC and I pull the 30amp (green) fuse.
novatz
Cross Hill, SC
I too pull the green fuse - easy. BTW - suggest you always carry an extra one in the event you drop/lose it.
'08 40' Monaco Diplomat Superslide
'08 Chevy Silverado with Rampage loader
'05 Gold Wing
'41 Spouse
'05 Cat
jenks60
MS. coast
We tow a 99 SL2 and turn the key to the first ACC click, the second one will turn on accessories. Put in neutral, install brake buddy and go.
NOTE- not all Saturns are towable.
jenks, fulltiming with the DW.
92 Southwind P3(32) 33 ft.
99 Saturn SL2
Rallys attended-TX 2, LA 2, MS 1, AL 2
MA. 1 drop in for visit.
Hjudge49
St. Augustine, Fl.
I just installed a circuit breaker on my Vue to replace the 30 amp Maxifuse. ( not my idea, got great instructions from a member of this forum). It was a real simple job. Now I don't have to open the hood and pull or replace the fuse everytime I tow.
