gouficanuk
quebec city
j have seen a deisel purification systems on the net
that clean,purified,bring the deisel at is rafinerie
state
as anyone heard of it or maybe install it would be
curious to know
the site "dieselcraft.com/productinfo_1.htm
Lug_Nut
Newmarket , Ontario, Canada
I don't believe this type of purifying the fuel would result in any fuel savings. It may avoid plugged filters, or extending filter changes, but at the expense of something else.
'07 Newmar Essex 45' ISM 500 4 slides
itsalleasy
Link
Looks like an expensive over hyped add on. When I see "vortex generator" I feel like I am being baffled with bs. You could change filters a lot for that kind of money.
chuck4788
West of the Middle
Depending on the type of diesel it will have a 2-10 micron filter and most of the fuel that passes thru the filter will be returned to the tank, only a small amount will be burned by the engine. In one to two hours of driving all of the fuel in the tank will pass thru the filter.
I agree with the previous poster.
Chuck
02 Beaver
505hp C12 Cat
Trailblazer toad
John S.
Northern Virginia
These type of fuel polishing systems are used on boats since you may have 8000 gallons and poor fuel from all over the world.
John
2001 42' Foretravel U320
2007 Bornfree 24 Painted
2001 Jeep Wrangler
2007 Burgman 650 Executive
Susie and Dolly (Cavalier King Charles Spaniels)
Dolly now in our hearts and thoughts 8-27-05
Doodle a Black and Tan Cavalier
Lolly a Ruby Cavalier
Circleearth3
Mayberry
IMO a fancy Fuel/Water Seperator, which you probably already have on your coach.
loedman1
Napa, Ca.
gouficanuk wrote: j have seen a deisel purification systems on the net
state
curious to know
I suppose it would work if you could find those various additives that you would need to replace should you be successful in returning your fuel to it's newly refined state.
edited 12/28/07 10:30am by loedman1 *
