RV.Net Open Roads Forum: Truck Campers: Tork Lift Info
 > Tork Lift Info
Moomba2002
Sebastopol, CA
Posted: 01/02/08 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
I have a chance to buy a new set of Tork Lift tiedawons for $275.00 for my 1999 Ford. The only problem is the rears are for a OEM Hitch and will not work with my Reese. My main question is there any market to sell the rears and and buy the correct part or should I just buy a new complete set? I could also use the fronts and stay with my Happijac rears but I don't know if that poses any problems. Thanks.
1999 Ford F350 DRW 4X4 PSD 6spd.
Banks Stinger Package
Fords upgraded Air Intake System
ExtremeAire 150 PSI 100% Duty Cyle on board air w/4gal. tank
Air Bags & Rancho 9000's
2003 Arctic Fox 1150 loaded except solor
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Posted: 01/02/08 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure they won't work? I suggest calling Torklift and double checking. If they are the kind that slip into the open end of the hitch you might just need the adapter that lets them fit a larger opening.
Also you might want to try them before giving up. I was told my 04 rears wouldn't fit my 07 due to a slightly different mounting angle but they work just fine.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
Moomba2002
Sebastopol, CA
Posted: 01/02/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
No I am sure since the reese doesn't have an opening in the end of the receiver. The part I need will have a flat plate that will bolt to the side of the receiver.
1181guy
Los Angeles, CA
Posted: 01/02/08 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
R3500
2008 Ford Superduty with Lance 1181.
AnEv942
CA
Posted: 01/02/08 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
All you really need is the mount arms that will bolt to the Reese (after drilling), unfortunatley they dont sell em seperatly. I went thru that when I switched recievers and had to replace the rear Torklifts.
A competetant welder could cut and add the bolt plate to rear mount &bolt to your Reese ?
Actually youd only be saving bout a hundred bucks over new, plus paying to modify or odering just the rears not sure if youd save anthing. http://store.towshop.com/store/products.asp?page=2&Category_ID=144 is one of the places for prices..
Mark
01 Ford 250 4X4 DRW Diesel, 01 Elkhorn 910
Air lift w/in dash controls
Rancho shocks
Torklift mounts
Our camper projects page
BradW
Flat Rock, Alabama
Posted: 01/03/08 03:43am Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind that Reese says not to cut, weld or drill on your Reese hitch.
Brad
Caution: Possibel defective spelling above; spell checker is DOA.
Our Truck Camper Photos
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Visit the RV.net Blogs
davedye
New Columbia, Pa. 17856
Posted: 01/03/08 09:42am Link  |  Quote  |  Print  |  Notify Moderator
That't what I did, I have a Dodge, however, the Torklifts used the holes I needed for the Reese hitch. I drilled holes in the side of my Reese hitch and mounting the Torklifts to it. No problems in two + years.
Dave
2006 Dodge Ram Dually, 3500 Quad Cab 4X4, 4.10 Gears, Cummins Diesel
2008 Lance 981 Max, Torklifts, Class V Reese Tow Beast with 24" extension, Torklift Stable Loads
2005 Triton DV 176 DC-F Magnum w/150hp Mercury Optimax
Silverado_55
Idaho
Posted: 01/07/08 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
The Tork Lift is a good product for keeping the camper in the truck but that is about it. I had some on my Silverado and the camper was all over the place. I switched to Happijac and the moving stopped. I now feel like the camper is part of my truck. The Tork Lift bars were allowing the camper to sway and one side would go limp and then bang tight. I didn't want my camper damaged like my friends camper. I think the frame can also be damaged too. I have been very happy with Happijac. I spoke with other camper owners at the campground and they have been very happy with the service and products of Happijac. They make excellent electric jacks too.
Silverado
 > Tork Lift Info
