RV.Net Open Roads Forum: Class C Motorhomes: Kodiak Headlights Again
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Kodiak Headlights Again
Doug_H
Gold Bar, Wa
Posted: 01/16/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
dsteinman wrote:
the stock "low" beams are next to nothing.
I know, trying to find a space at the RV park at night was nearly impossible. So, I also ordered some fog lights to help at these times.
David
I have thought about fog lights but where do you mount them and where are you purchasing them ?
'07 Jayco Greyhawk 33DS
mfa
Posted: 01/16/08 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
How about in those two square holes in the bumper?
MotherTucker
Atlanta, GA
Posted: 01/16/08 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah I know what you mean - but good headlights don't seem to help much in that situation - it always seems to be at right angles to where the headlights are shining. I put 2 sets of HIDs on the front of my Kodiak and it doesn't help much when looking to the side. For that purpose, I would like to add a (remote controlled) spotlight like Stryker search lights. But they're a bit pricey, so meanwhile I make do with a powerful handheld flashlight. Another situation that could use lighting improvement is when navigating those tight campground loops at night. There's invariably some tree or the edge of the pavement that you have to just miss in order to make the turn, and you can't see it back by the rear wheels because it's too dark. For that, I want to add Guide Lites. That's my next project.
I might add that I've never encountered a campground loop road that could not be navigated in the Kodiak. Any bigger, and it would not make some of them - but it's just barely small enough and maneuverable enough to do it. It's been a great performer.
az99
N.Y.
Posted: 01/17/08 06:27am Link  |  Quote  |  Print  |  Notify Moderator
dsteinman wrote:
I have these Hella headlamps on order. The 165mm Free Form.
http://www.rallylights.com/hella/165mm_lo.asp
I will let you know how these work when I get them.
David
Thanx for that link. I will be within a few miles of that place in a few days. That unit looks like it should be a direct replacement. I will take one of my bulbs along.
dsteinman
Los Alamos, NM
Posted: 01/17/08 08:34am Link  |  Quote  |  Print  |  Notify Moderator
I will mount them somewhere on the bumper, probably as near the sides as possible since I want as wide as possible light when I use them.
550 Clear Fog Lamps
That is a really good idea. A couple on the side facing forward and a couple facing backwords would be really helpful. Fortunately, the RV park I was at had pull-thrus. It was unlit though and it was very hard see where the road was and where the spaces were.
You should check with them first. These headlights were on backorder but they are expecting them this week.
David
2007 Four Winds 34H
2005 Dodge Durango 5.7 Hemi
az99
N.Y.
Posted: 01/18/08 11:57am Link  |  Quote  |  Print  |  Notify Moderator
It looks like we have a solution to the problem. I picked up the lamp housings shown in the above link. They are a direct replacement for the stock 4656 sealed beams. I actually tried them. You can use any H4 bulb that you want in them. They come with a wiring adapter socket to plug into the stock plug and adapt to the H4 bulb. The H4 bulbs are available in anything from stock wattages to offroad power.
Thanx again for the link.
dsteinman
Los Alamos, NM
Posted: 01/18/08 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Great, I can't wait to get mine and try them.
David
Gene in NE
Omaha, NE
Posted: 01/18/08 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
MotherTucker wrote:
...Yeah I know what you mean - but good headlights don't seem to help much in that situation - it always seems to be at right angles to where the headlights are shining...For that purpose, I would like to add a (remote controlled) spotlight...But they're a bit pricey, so meanwhile I make do with a powerful handheld flashlight...
I happen to own this flashlight Brinkmann Q-Beam (Blue Max) and would take it along if I had a need. Used it to locate lost cattle at night. Mine is older and only has 200,000 candlepower.
2002 Trail-Lite B Plus 211-S w/5.7 Chevy
Gene
MotherTucker
Atlanta, GA
Posted: 01/18/08 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Kinda getting a bit off-topic here, but I can't resist when it comes to flashlights... my son says I have a "flashlight fettish"!
I recently tried an (estimated) 30 MILLION candelpower HID handheld spotlight. It had a lead-acid battery in it. We couldn't see how far it really shined because the clouds got in the way! It was spectacular. Sams club was selling them. Here's the exact unit
mt
dcowley
Texas Panhandle
Posted: 01/18/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Same here I carry this one with me. Makes setting up at night a cinch.
Kawasaki light
