RV.Net Open Roads Forum: Class A Motorhomes: House Batteries Not Charging
 > House Batteries Not Charging
mdprince
Santa Clarita, CA
Posted: 01/05/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
We are currently snowed in in Mammoth,CA and all is fine with our 50 Amp hook-up. The house batteries have showed full charge for the last 6 days BUT, last night I looked at the monitor and they were @ 12.2V and falling, and don't seem to be charging.
I have temporarily hooked up a car battery charger to them so they don't die completely.
Anyone have any suggestions as to what to check or look for?
Xantrex 2000
2006 Rev 40E
Thanks,
Michael
2006 Revolution LE 40E
2004 Jeep Rubicon Toad/Brake Buddy or
20' Toy Trailer/Quads 'n Dirt Bikes
trails2004
Wyoming
Posted: 01/05/08 10:16am Link  |  Quote  |  Print  |  Notify Moderator
What is the temperature outside??
The reason I ask is that I understand that the Freedom Combi Inverter/Charger operating range is 32f-104f.
While I'm not sure what brand or type of charger you have I took a guess with your Xantrex 2000 link
Or
Check the DIP switch settings on the remote control panel, you maybe able to change the settings.
Freedom 20 Owners Manual
You could always call Randy at Best Converter 1-888-828-1893
* This post was last edited 01/05/08 10:38am by trails2004 *   View edit history
2002 Dodge Ram 2500 SLT 4x4-AFE Cold Air,4"Exhaust,Toyos,Ranchos,Dual Air III- Firestones 2004 Hallmark Cuchara XL 9.5 w/Carbon Fiber Roof, WFCO 9845,Xantrex XBM,Honda 2000,1997 Grumman GV19TC- Crew Wifey,(Odin,Bridger & Sam,Wirehairs)
trop-a-cal
Palm Coast Fl
Posted: 01/05/08 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Check the grounds they might be rusted or loose.
Norm Payne
Livingston, TX
Posted: 01/05/08 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Temperature should no make any difference. I have operated the same inverter/chager down to -8 degrees. Does the panel show it is charging? Or does it have a red light? I had the same problem a few years ago and there was no indication of a problem except the batteries were not charging. I connected a 6-amp charger to keep the batteries charged until I could get to a service facility a week later. I turned out to be a defective circuit board.
Norm
2005 Dutch Star 4015, Cummins ISL 370 hp
2007 Honda CR-V
See Ya Down The Road
http://www.seeya-downtheroad.com
mdprince
Santa Clarita, CA
Posted: 01/05/08 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all!
Now that I have some daylight and light snow I will pull the manuals and get the OEM meter out and check a few more things.
Xantrex Freedom 458 / 20
mdprince
Santa Clarita, CA
Posted: 01/05/08 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
One of those blizzard dang dumb moments!!
I found the reset button on the front of the unit and all is well. All hail the manual! lol
mp
chuck4788
West of the Middle
Posted: 01/05/08 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
My ProSine often locks up when connected to shore power, I suspect spikes or surges. I must power it down and restart it (with a dip switch on the side) and it then reboots and begins charging. Check your manual for the location of a On-Off switch or a reset button. I can not correct the lock up condition from the remote panel.
Good luck
Chuck
02 Beaver
505hp C12 Cat
Trailblazer toad
trails2004
Wyoming
Posted: 01/05/08 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Just the messenger- some things just dont work-when it is cold
Xantrex Combi
General Specifications
Operating temperature
32°F-104°F (0°C-40°C)
Storage temperature
Optional remotes
Freedom Remote or Link instrumentation
Dimensions (H x W x L)
7.0 x 9.75 x 12.0” (178 x 238 x 305 mm)
Weight
31 lb (14 kg)
Warranty
30 months
Part numbers
81-0114-12 (12 volt)
81-0114-24 (24 volt)
84-2056-01 (Remote Panel, 12 V)
84-2019-02 (Link 1000, 12/24V)
84-2000-06 (Link 2000, 12/24V)
Drew&Corinn
Pleasant Grove, Utah
Posted: 04/10/08 12:02am Link  |  Quote  |  Print  |  Notify Moderator
I have the same coach and the same issue... what was your determination?
Thanks,
Drew in Utah
2005 GMC Sierra D/A Crew Cab,Airsprings,4 inch AFE intake-exhaust, Edge w/Attitude+More
2005 Fleetwood Revolution40e
Soon to be Ex-Wife Gets - Cardinal 31BHLE (Maple),4.2 LP
2006 Polaris Ranger XP Browning
2-2008 Polaris Sptsmn 90s
CANAM 800XP
