RV.Net Open Roads Forum: Travel Trailers: Cant believe it
 > Cant believe it
Hoseman
Westfield
Posted: 01/06/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
It was a Beautiful day by N.Y standards in Jan. Almost 50 so I decide to go to rv to see how things were holding up after winter storm dumped 14 inches of snow which has since melted. I know I winterized it turned all appliances off to include propane. Apparrently not!! It was cold when I her to bed.Anyway I opend the door to hear a blower running and it was quite warm inside. I DIDNT!!
Yes I did leave the furnace on although set to 60 degrees !@#$e$^&&&%$#$$@$!!! I was surprized to find the blower running and the furnace still working I had just filled the 2 tanks as I do every year that way I dont have to worry about it now because they are both almost emty. I was very surprized the house batterys ran this long without being charged. Iwas wondering if anyone else has done this or am I the only @#$%$##$$##&$% That has done this. Thank god this doesnt appeared to have damaged anything.
coolbreeze01
Redding, Ca
Posted: 01/06/08 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
So, what kind of batteries?
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
Dixonmatco
Santa Rosa, California
Posted: 01/06/08 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
You are not the first and certainly not the last...
Look at the bright side... Nothing was going to freeze and moisture was under control..
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
movein
NC
Posted: 01/06/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
well that is why you use a battery disconnect then you wouldn't have to worry about it. I am sure something like that would've happened to me though.
skipnchar
Topeka Kansas USA
Posted: 01/06/08 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Running the furnace shouldn't damage anything, that's what they're intended to do. About the only danger was running down your batteries and THEY could have been ruined if flattened then frozen. How long had it been running without being connected to shore power? I know my two 30 lb. tanks will run my furnace for a week or two even in sub freezing temps but my two trojans wouldn't last more than about 3 days.
KC8WX
OH IO
Never done that yet but my time will probably come so to prevent that I shut off the LP Valves, AC Power and remove the Battery. I also make visits to the side yard to see the girl every few weeks just to check on things after a rain or snowstorm, see if any leaks on ceiling or maybe unwelcome visitors found there way inside.
Pretty amazing it ran that long on the batteries and LP! Guess you could Dry Camp in the Winter a long time!
2006 Durango SLT 4.7L, 545RFE, 4.10 Motive Gears with TracLoc 2WD AIRAID Cold Air Intake, PML Deep Tranny Pan, KYB Shocks
2007 Wildwood LE 27RB
Equalizer Hitch
Prodigy Brake Controller
fla-gypsy
North Florida
Posted: 01/06/08 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Sound like you have some very good batteries.
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
Hoseman
Westfield
Posted: 01/06/08 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
I was surprised as well I use Mariner boat batterys they have never failed me before but it has been almost a month since since I was at the trailer. Thats why Iwas so shocked. I do make sure the LP is off. This is the first time I left anything on. Thanx for your replys. I have all kinds of luck mostly Bad that why Im concerned about the blower motor. Thanx again Happy camping your the best!
Hornet28BHDS
Parker, PA
Posted: 01/06/08 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
It happens to everyone! Just be glad nothing is hurt!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
maxum1989
Vancouver Canada
Posted: 01/06/08 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Something doesn't seem right. A month of running the furnace in winter and it is still going! Most people complain that they can't get through a long weekend of camping without draining the batteries. You've just done ten times that. Something seems off. You sure someone isn't pulling your leg?
 > Cant believe it
