RV.Net Open Roads Forum: Tow Vehicles: 2008 2500HD 3:73 or 4:10
Search only in Tow Vehicles
 > 2008 2500HD 3:73 or 4:10
kdkrause
Redcliff AB Canada
Posted: 01/10/08 08:38am Link  |  Quote  |  Print  |  Notify Moderator
I am looking to buy a 2008 2500HD crew cab 4X4 to haul our 8,000 lb trailer around. All the trucks my local dealer has in stock come with the 3:73 gears. I am looking for advice on whether the 4:10s are still recommended or will the 3:73s do the job with the new 6 sp transmission.
I don't do a large amount of towing, probably 6 or so trips during the summer.
Is it worth ordering a truck with the 4:10s and having to wait or should I just go for the 3:73s?
downtheroad
Puget Sound
Posted: 01/10/08 08:44am Link  |  Quote  |  Print  |  Notify Moderator
I could be wrong, but when I ordered ours the 4.10's were not even available in the 6 speed Allison..??
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
Capt Skup
Southern Maryland/Nantucket
Posted: 01/10/08 08:48am Link  |  Quote  |  Print  |  Notify Moderator
I do not think that Chevy/GMC gives you a choice on SRW 2500 series trucks, it is 3.73 or 3.73. Take your pick. I think 3.73 axles combined with the diesel/auto is probably about perfect when considing the tow rating of the 2500HD.
Capt Skup
AD-1(AW)USN Ret.
Wonderful Wife, 3 beautiful Daughters
"Never get in a battle of wits with an unarmed man"
2008 F-450 Lariat 4x4
2008 Honda Odyssey EX-L
SunlineF281SR
SeaRay215EC
http://community.webshots.com/user/CaptSkup?vhost=community
donn0128
Pronounced Ore-gun
Depending on the motor choice, 3.73 is the only available ratio.
Donn
Johnwil
Cumberland, Wisc
Posted: 01/10/08 08:50am Link  |  Quote  |  Print  |  Notify Moderator
I had the 3:73's on my 2500HD with the 8.1 and Allison transmission and had no problems pulling a 5er that had a dry weight of almost 12000#'s. I think you would have no problem pulling that rig with 3:73's, however if you go a lot larger you might want to wait for the 4:10's. The general feeling is that you will only loose about 1/2 mpg with the 410's versus the 3:73 but you will probably get better mpg's towing.
John & Joan
3500 Chev 2008 Dually with 6.6 TD and Allison Trany
34RLQS JAYCO DESIGNER Fifth Wheel
Retired
kdkrause
Redcliff AB Canada
Posted: 01/10/08 08:52am Link  |  Quote  |  Print  |  Notify Moderator
I should have specified I am going with the 6.0 gasser. There is an option for 3:73 or 4:10 gears.
Ag Teacher
Oklahoma
Posted: 01/10/08 08:59am Link  |  Quote  |  Print  |  Notify Moderator
This statement is true only for the diesel trucks. With the 6.0 gasser, you have a choice of 3.73 or 4.10.
2005 Explorer by Frontier RV T265
Yamaha EF3000iSEB Generator
2005 Chevrolet 2500HD Ext. Cab LS, 4x4, 6.0, 5 speed manual
OldSoldiers
Sierra Vista,AZ
Posted: 01/10/08 09:25am Link  |  Quote  |  Print  |  Notify Moderator
I'd go with the 4.10 if you can get it. See my signature. My 5er weighs in at 7200 (+-200) lbs loaded for the road, and while I'm ok with its performance I surely wish for a new diesel. That said, you will be towing a bit more than I and if you want to maximize your TV's performance get the 4.10
Good luck,
Wife and I are both retired Army. Wife with 20 years and I with 33 years active federal service.
Tow Vehicle: 2005 Chevy Silverado 2500HD, 6.0 gasser, 4.10 rear axle and all the bells and whistles.
5'er: 2006 Jayco Jay Flight 245RBS
Capt Skup
Posted: 01/10/08 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Since you are talking gasser, I would choose the 4.10 gears also. Don't take what the dealer maybe pushing, he is just trying to sell the trucks that are on the lot. Buy what you need/want. I know it is about impossible to find a manual transmission in a well equipped HD pickup these days, so sometimes you have to order it, probably much like trying to get optional gear ratios.
abulka
Brampton, Ontario, Canada
Posted: 01/10/08 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I was in the same boat as you as far as camping and towing requirements. We are waiting on our rockwood 8317SS.
For the towing vehicle, I went with 2008 GMC 2500HD Sierra 6.0l and 4.1 gears. Mine is a factory order as I'm not in a rush. They say it takes 6-8 weeks to get the vehicle with a factory order.
To me, it was rather obvious to get the 4.1 - from reading (as I don't have any experience with pick ups) the advantage is obvious. From a cost perspective, it is a $0 option. Yes, you might pay a little bit more in gas when not towing.
