RV.Net Open Roads Forum: Forum Technical Support: trying to post picture
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > trying to post picture
walcoffl
So. California
Posted: 01/10/08 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
RVSnowbird
OR-NV-AZ-OR
Posted: 01/10/08 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
first walcoffl, you need to post with the toolbar icon and enter that link there.
Unfortunately, it comes up as a red x so you need to confirm that is the correct address.
Your last attempt, http://s169.photobucket.com/albums/u233/walcoffl/?action=view¤t=DSC00615.jpg was missing the h in "http://"
RVSnowbird
RVSnowbird
OR-NV-AZ-OR
Posted: 01/10/08 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Here's your picture using the Photo Editor:
1024x768 is too large to post so "width=640" was entered between the "jpg" and the end tag of "img" in brackets.
* This post was edited 01/10/08 06:35pm by RVSnowbird *
RVSnowbird
OR-NV-AZ-OR
Posted: 01/10/08 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
walcoffl, please confine your testing to the same post using Edit. I deleted your previous attempts.
Note the correction note on resizing your photo.
For an explanation of why this is nececessary, please see Screen resolution for pictures in text
pulsar
Lewisville, NC
Posted: 01/10/08 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a simple way to post pictures, if you are using Photobucket.com and the picture is no more than 640 pixels wide, all you have to do is click on the bottom URL from the 4 under the thumbnail, (just clicking will copy the URL) and paste it in your post.
If the picture is greater that 640 pixels wide, you can insert a space and width=640 after the .jpg or .gif as in the example below
[IMG]http://i33.photobucket.com/albums/d90/tfix/PhotobucketPictureLinks.jpg width=640[/IMG]
Don't quote this post to reply. Doing so will cause what looks like brackets in the example above to actually become brackets. Your quote will display a distorted blow-up of the above picture and not the example.
Tom
tknight
cleveland, oh
Posted: 01/19/08 10:27am Link  |  Quote  |  Print  |  Notify Moderator
http://i255.photobucket.com/albums/hh134/tknight321/rearend.jpg
RVSnowbird
OR-NV-AZ-OR
Posted: 01/19/08 11:07am Link  |  Quote  |  Print  |  Notify Moderator
tknight, here is your picture using the toolbars Photo Editor
Just enter that URL or link into the top box and since the original size was 406x406, no height/width adjustment was required.
RVSnowbird
gm seller
holland ny
Posted: 05/22/08 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
[/img]
pulsar
Lewisville, NC
Posted: 05/23/08 05:26am Link  |  Quote  |  Print  |  Notify Moderator
gm seller,
See your private messages.
Also, I posted a suggestion here.
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
