RV.Net Open Roads Forum: Need to run coffee pot early in AM
 > Need to run coffee pot early in AM
Page of 10
Corky52
San Diego, CA
Posted: 04/02/08 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
RCDave,
I take it you don't believe in rules, must be nice. I've yet to see a "quiet" genset!!!
I just make coffee when the genset is legal and keep it in a thermos, quiet in the extremem, not even any banging pots and pans.
----------------------Corky---------------------------------
Friends come and go, but enemies accumulate
ca-rver
Citrus Heights, CA
Posted: 04/02/08 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
Guess it takes all kinds....
For me, nothing can replace the smell of coffee percolating on the stove... I think 'perked' coffee tastes better than the drop. Plus, the coffee is actually hot, not just 'warm' like my home drip coffee maker...
It's great reading all the different opinions. Guess everyone needs to decide for him/herself what works best.
RCDave
Simi Ca
Posted: 04/02/08 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I didn't read the first page of this thread to see when that coffee was to be brewed.
Revision - Just make the coffee right right before generator hours end the night before. Then store in a thermos.
FYI - My genset if whisper quiet. However, I don't run it during non-allowed hours
Corky52 wrote:
RCDave,
Mongo71
Longwood FL
Posted: 04/02/08 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
WaltinColo wrote:
Ya know...
This can all be solved by just cracking a beer instead of coffee...
Now, lets get out there N CAMP!
FINALLY, a voice of REASON!
2004 Lincoln Aviator
1997 Starcraft Venture 1706 P/U The "Tiltin' Hilton"
If you are going to be dumb, then you better be tough!
Dave H M
IL
Posted: 04/02/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
When I was driving a truck, I had a perc pot that plugged into the 12 V power jack. A little slow but the coffee was good.
But I know you want an inverter
tuxsteveo
Wisconsin
Posted: 04/02/08 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Coleman stove top automatic drip and it works really good a bit slow but it does warm up the trailer a lot great for chilly mornings. But a good French press is just a coffee drinkers joy when camping. I rarely use the French press at home but out camping just a tea kettle of water, some fresh grind, and your all set. You'll never be hard pressed for coffee in the mornings....
MrWizard
Van Nuys, Ca
Posted: 04/02/08 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
jtbmoore wrote:
This might be a stupid question but how does the water move from the reservoir through the coffee and into the pot. I guesss I always thought their was a little pump on an electric coffee pot that pumped the water through.
heat moves the water, the electric ones are the same way, heat.. NO motorized pumps
Connected via Verizon Via LG Dare VX9700
Maximum memory has been reached !
AO_hitech
SF Bay Area
Posted: 04/03/08 11:28am Link  |  Quote  |  Print  |  Notify Moderator
The same as a peculator (the water "flash" boils and the rising bubbles force some of the hot water up the tube), it just doesn't drain back into the "reservoir" after filtering through the coffee grounds.
BTW, an absorption reffer uses the same principle to move the ammonia to the top.
pnichols
Santa Cruz Mountains
Posted: 04/03/08 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
I don't even mess with percolating coffee, as I put so much cream and sugar in it that the coffee taste is irrevelent.
I use a titanium backpacking cup, with instant coffee, water, and sugar in it - then just sit it directly on a propane burner set on super low flame. It's ready in a couple of minutes with NO noise to wake the DW. I add powdered creamer after it's hot and wala - done. Don't have to open the refrig. Water is from a drinking water jug, so the RV pump isn't needed to do it's noisey thing. I don't wash the cup the whole trip - just wipe it out with a napkin.
I do carry on board two generators and an inverter, however, "just in case"!
Phil, 2005 E450 Itasca 324V Spirit
MaddogBC
Kelowna BC
Posted: 04/03/08 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thought i'd kick in my vote for the french press
DW and i take our coffee very seriously and are very attached to our home model as well. we have suffered many a camping morning waiting on various painfully slow coffeemakers. a friend recently suggested this
http://www.canadiantire.ca/browse/produc........88289&assortment=primary&fromSearch=true
We put in twice our normal amount of grounds, pour NEAR (let stand 10 seconds) boiling water in, let stand 3-5 min, press, and enjoy delicious coffee very fast. get's rid of the friends with their cups out quickly enough too!
Good luck in your search
Rob
* This post was edited 04/04/08 08:28pm by an administrator/moderator *
Page of 10
