RV.Net Open Roads Forum: need tips for non-comm class A - update on Pg 2
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > need tips for non-comm class A - update on Pg 2
vwcardoc
canyon country ca
Posted: 01/13/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
They did not make me parallel park.
The instructor said that was only for big trucks.
the test was not that hard, if you can back into your storage spot your good.
2006 f250 psd 4x4
2007 Stellar 31lks
WR450
crf150 (wifes)
Baby girl
Hap Hazard
Mammoth Lakes
Posted: 01/13/08 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Well here's the steps for anyone needing them. My unit is a F-250 super cab/short bed 4WD. The TH is a WW FSC2800 bumper tow. The test course is 12' wide by your overall rig lenght plus 10'. This 10' is a magic number that makes everything work well.
1)Pull along the cones straight and parallel, place the left front cone (LFC) 2/3's the way between your last axle and the Right rear corner of your TH (the 2/3 is towards the rear of the TH).
2) Cut the steering wheel hard to enter the space at a 30 degree angle, watch the right side mirror.
3) When the right rear coner of the TH reaches the center of the parking space cut back hard to straighten out. On my truck it was full steering wheel lock.
4) You will begin to see the left rear corner of the TH come back in your left mirror. Aim the left rear corner of the TH 2-3' inside the Left rear cone. (With the width of the course you don't have to worry about the right side.) As you continue let the Left corner move to 1-2' inside the cone.
5) Begin to striaghten ASAP and back as far back as you can towards the cone.
6) Look over your hood or along the left frt fender for the L/F cone and pull forward to help straighten out. Again aim for 2' inside the cone.
Note: At 1st I was concerned about the L/F cone as I couldn't see it, but found that I never got close to it. Also, If you cut back as the Right Rear corner crosses the centerline you won't cross over the curb border.
Try this and adjust as needed. Hope this helps someone.
Hap
mtnrider
Poway CA
Posted: 01/13/08 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Hap,
I did this in July. On each item you are only allowed to correct 2x.
Backing straight was not that hard, I just put the truck in 4L so it would idle real slow and straightened accordingly. It can be tricky when you correct because if too much you loose sight of the cones.
I was asked to do my parallel parking on the street and I just had to pull up to a curb.
The dock parking was the hardest part for me. I have no idea why we need to know that but we do. you are required to back into a dock from a 90 degree angle. Making the turn was fine, they give you enough space to correct and back straight. The hard part was backing far enough but not hitting the cone, (dock), you cannot see. You have to be within 3' of the dock. Just get used to knowing where the back of your trailer is for that one.
Since I was allowed 2 corrections, I used them when needed. Having the truck in 4L also helped. I'm sure the truck wasn't too happy on pavement but I passed.
Once you get passed that, the driving is a breeze. Just go slow. Here is my test. I'm sure you will do better.
5 Bikes, all hard pack!
KTM 525/543 CA Lic mine
KTM 250/351 CA Lic wife
KTM 105 SX son. KTM 65 SX son, Honda 230 daughter
07 LE 3505 pulled by Stock DMAX 2500
Hap Hazard
Mammoth Lakes
Posted: 01/13/08 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
mtnrider,
I saw your test sheet from another post and copied it already. I've really not had any concerns except for this parallel thing (and that's because I'd never done it before. I now have all my marks to get through it and it doesn't appear to be a big deal. Just hope I can help someone else. I had hoped that someone could have given me a hint before I drove down to Bishop to start practicing.
Take care and thanks,
Hap
nevadanick
Elko, Nevada
Posted: 01/13/08 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
I took the class A test in Ca and when parallel parking only had to put the trailer in the space, he didnt care where the truck ended up. It was easy and i did the test with a crewcab pickup and 40ft gooseneck.
sin cal hd
Hooligan #109
Posted: 01/13/08 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hap
Just out of curiosity where you allowed to have the truck jack knifed with the front end sticking out a little? I know with the CDL testing that is ok.
My Pics
05 2500HD Bowtie Duramax/Allison CC LT 4x4 6in lift
06 Rhino
07 Suzuki LTR 450 and of course
Wife and Baby Boy
F-TROUP
VISALIA, CALIF
Posted: 01/15/08 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
The only parallel parking consisted of pulling over to the curb, You would be surprised how many people don't think about the trailer tires being wider than their truck tires. Watch for signs an power poles when doing this. Also all the cone stuff is more for checking your depth perception along with the ability to handle the rig your driving.
Hap Hazard
Mammoth Lakes
Posted: 01/15/08 11:42pm Link  |  Quote  |  Print  |  Notify Moderator
sin cal hd,
I haven't taken the test yet. I'll let you know when I find out.
Hap
pcassidy111
California
Posted: 09/15/08 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
Very helpful, thanks
Pete
Rhinojoe
Inland Empire
Posted: 09/20/08 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Hap
It's OK.
It's the same exercise as the alley docking.
