sdagro
Independence,LA
Has anyone ever replaced a regular crank open ceiling vent with a power vent from one of the various manufacturers? If so how do you get the power to it? Would like to get one for the bedroom in our 5ver. Thanks in advance. Steve
cabanaman
middleburg florida
I did it on a previous TT. I got the power from a nearby cieling light.
Retired Navy
2007.5 Dodge Ram SLT sport 2500 quad cab 6.7 cummins,6 speed auto with exhaust brake.
2007 Open Road 378SA4S-5 quad slide.
eisleyr
Milton, Pa, USA
I replaced my vent with a Fan-tic fan. Had a ceiling light near by so I used a steel fish line (made for pulling wires) and pushed it through the foam insulation from the vent location to the light location and pulled power wires from the light to the vent (now fan) location. If you have a wood frame around your vent location you may have to drill a hole through the wood first.
Rob & Kathy
97 Southwind
2004 Honda CR-V
Good Sam Member since 1992
Admiral
Lodi, Ohio
Ceiling lights are usually the easiest + and - to tap into but if you can get to a connection with a larger wire you may be better off. Ceiling lights may be #18 or 20 wire which could cause a power loss since the fan will draw much more current than the light will. Your lights may dim with the fan on. Also, if you lights are on a wall switch it will be a hassle turning the lights off when the fan's on.
Just some things I've experienced in the last few rvs.
Good luck
2004 Damon Daybreak 2960F
05 Honda Element LX
In a democracy two wolves and a sheep can vote on what to have for dinner.
Wherever I happen to park
Most of the crank open vents already have a small fan (Way too small) and thus a 12 volt line feeding them, and as they say 'Ththththattttts alll (you need) Folks"
Deen
Vancouver, WA
I did it on one TT, it was prewired for a 12 volt fan so no problem.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Bronco4me
Ridgecrest, CA
I replaced my crank vents with ShurFlo Comfort Platinum fans. Slipped right in and I tapped into nearby ceiling lights. No problems at all, even with all lights on and the fans producing mini-cyclones inside the motorhome!
Bronco
1992 Holiday Rambler Aluma-Lite 33CSXS
2005 Yukon Denali
1990 Bronco XLT Fishin' wagon
sfischer
Stafford, VA
Did the same install as Bronco. Easy, quick project. Works great.
http://community.webshots.com/user/DuraFox
Currently:
2004 Chev 2500HD, D/A,Ext. Cab, Lg. Bed, 2WD
2004 Arctic Fox 29 5-E 5ver
Prior:
1994 Chev 2500HD, 7.4L, 4.10
1994 Jayco 3250RLR 5ver
1990 Chev 2500, 350, 3.73
1992 Terry 27' TT
1991 Terry 19' TT
Listermann
Cincinnati, Ohio
We had one installed in the bedroom. I am not happy with its utilization. It seems that the window for using it between heating and air conditioning seasons is rather narrow here in Ohio. I could see it used a lot if we boondocked, but we don't.
Retired63
Nebraska
Have done it. Just do it! Ya won't be disappointed in that fan, they blow and suck like no other. Great customer service too.
J
“There are hundreds of millions of gun owners in this country, and not one of them will have an accident today. The only misuse of guns comes in environments where there are drugs, alcohol, bad parents, and undisciplined children. Period.” Ted Nugent
