howhafner
The heater works fine but, from the outside, sounds like a blow torch. I've heard or read that you should not hear it over 25 ft away and this unit, an Atwood, can be heard upwards of 100 ft. Disruptive to other campers. Ideas?
RVSnowbird
OR-NV-AZ-OR
moved from Forum Technical Support to the General RVing Issues forum
howhafner, please check your Private Messages for an explanation of this move.
RVSnowbird
DutchmenSport
Indiana
If the neighbors start complaining, invite them over, gather around the water heater on the outside, wait for it to kick on. When it does, have everyone ready with marshmallows on their sticks. Put all the marshmallows in the heater's exhaust area, and roast the marshmallows.
Chances are, you'll have someone outside standing by your water heater just waiting for it to blast on every time you take a shower or do dishes!
Really, sorry. I don't have a clue what you should do.
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
skipnchar
Topeka Kansas USA
Your water heater should only run for about 15 minutes and every other RV in the campground will ALSO have a hot water heater. If this disrupts them you've found a particularly easily disruptable group to camp with so make sure you're wearing rubber shoes when you walk around.
Rvpapa
Alberta , Can.
Too much air in the mixer tube to the burner will make it sound like a loud blowtorch.
ART.
howhafner
Thanks for replies......believe I'll go with Rvpapa's thoughts, however. Howhafner
dbbls
Missouri
Mine did he same thing. I called Atwood and talked to their service department. After confirming the air mixture was correct they had me to bend the exhaust outward. This made it much quieter. Open the cover and at the upper left side you will see the exhaust. It is about 4 inches wide and slopes upward at a 45 degree angle. at the outer most point, it bends upward for about one half inch. They had me bend this 1/2" flange outward until it was straight with the 45 degree part. This made the door harder to shut but it sure made it quieter.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
nny12972
NY
The tube is mfg. the way it is to "attempt" to keep the exterior door from getting "too hot."
J
BluegrassBill
Woodland, Wa. USA
RVpapa has it right. If you have the Atwood manuel checkout the adjusting aitshutter section. Too much yellow in the flame is too much air and will be a loud roar. Loosen the airshutter tube set screw and slide tube back and forth to find the sweetspot. Nice quiet blue flame. Now be careful too much blue will be sooty.
Bill & Kathy Francis
95 Itasca Sunrise 29RQ,P32 454 Chevy, Banks,ECM chip.Safe-T-Plus, Bilsteins, Super Steer Bell Crank, Stewart Stage 1 Waterpump, Severe Duty Fan Clutch, OilGuard Bypass Filter, Coolant Filter. Rear Tracbar. 1-5/8" Front Swaybar.
howhafner
again, thanks for good info!! Howrd Hafnder
