Glenn And Kitty
Breaux Bridge, LA
I have a Minnkota 45 lb thrust trolling motor. I need a new battery. Looking for one that weighs around 30 lbs or less but would still last a half day's fishing. A friend suggested a Gel ? type. Any suggestions.
Glenn
2006 Trail Sport 22QB
2006 F-250 Super Duty
SilveradoCamper
Idaho, south of West Yellowstone
No problem finding a smaller battery that weighs 30 lbs or less. Just don't forget your oars. More weight = more power, as all trolling motor batteries are of the lead-acid type.
1995 C2500 SE Ext Cab 8' Bed 8600 GVW 5.7L 4L80E 3.73:1 Locking Diff.
1993 11' Shadow Cruiser, A/C, Microwave, Awning, TV.
Timbrens, Monroe Reflex, Hitchco Tiedowns.
Michelin LTX M/S 245/75/16-E.
Stressor
Milwaukee, Wisconsin
I would avoid the gel type as they do not store well unless fully charged. You will have other things on your mind when coming in from a long day on the water.
Milton Findley (and Kerene)
A small piece of my mind...
KeninAZ
SE AZ
You might try one of the smaller lawn tractor batteries.
It may work for you if you don't use it a lot.
They weigh a lot less than a full sized battery.
The main problem is as I see it that the normal battery is not designed to be used as an RV or Marine battery with constant loads.
They are really only supposed to have one function and that's to start the car or truck they are in.
At that point the alternator takes over for the electrical needs of the vehicle and recharges the battery for the next start.
Jacksons
columbus,ohio
agm battery
an agm deep cycle battery may work well,pricey,but good. a lawn tractor battery would not last 15 min.
2002 Rockwood 8272s
1999 suburban 5.7 k1500
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Kajtek1
CA
Tractor or motorcycle might work for longer, than 15 minutes, but they have short lifespan. I think for the application Optima AGM are the best.
Easily available at Costco between soap and beer.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
Glenn And Kitty
Breaux Bridge, LA
I've located a 12V 32AH Gel Cell lead acid battery that weighs 31 lbs. Do you think 32AH will provide the power I need to troll around and fish for half a day? I have a 105 AH and it last a week but the reason I don't like it is that it weighs 78 lbs.
Glenn
Jacksons
columbus,ohio
it all depends on how much current draw the motor has,and how far you try to go in half a day. I would say try it, the will be also 48 less lbs for the motor to push
