joshjack
Alabama
Have an older fiver that is not real pretty to look at. Any of you ever tried repainting one? What did you use, etc?
It has tin siding. I plan on roughing it up and then recaulking everything, then using my spray gun to put an even Rustoleum coat on.
J
03 Ram 1500 Quad Cab with Hemi 5.7, HD tow package, K&N Cold Air, B&W Companion + Ball, Prodigy,
1987 Prowler 27.5',
Macbook Pro 17" (Fastest Vista Laptop , iPhone)
Me and the DW and our
2 Dogs: Jackson (golden), Pumba (min-pin)
Bedias Cougar
Bedias,TX
I didn't know you could use repainting and fun in the same sentence. I'm definitely not a Rembrandt. Just Kidding!
donn0128
Pronounced Ore-gun
If you want it to look good at the end of this process, then might I suggest a quality automotive paint.
Donn
CHV_FRK
Black Jack, MO
Definately prime as well. A local wholesale auto paint can also mix it for you in the spray cans. That might be the best way to go. Maybe add a little flex additive.
Dana and Natalie
2008 Chevy Silverado 3500HD LT DRW CC LB 4x4
2008 Jayco 35RLSA 38'9"
newk
Gillette, WY
I'm not sure how it would work on a camper, but I had an old airplane painted with Dupont Imron polyurethane enamel many years ago. Twenty years later people would still compliment me on the paint. It really held its gloss well -- never needed waxing or any of that horrible upkeep stuff. Its only drawback, other than cost of the paint, is that it's really hard and probably chips more than some.
CREATO
Beautiful Harvey N.D.
Can't say about a fiver but I helped paint my parents lake cabin 14x70 trailer. My folks bought it new in 1974 and in 2004 we painted it washed it off and painted it with a roller it turned out great even though I said it would not work.
I DON'T RENT OUT SPACE IN MY BRAIN
Al B
Cowtown
I agree with what was said a few posts back, automotive paint would be the best. The longevity of it sticking would be a proper sanding of every knook and cranny, some kind of sealer that will stick to aluminum, (for those bare spots) and paint away, single stage of course, unless you want to do the base/clear method. Single stage would be much easier IMO.
nypatnva
Amelia Ct Hse Va
I have repainted two camping trailers and a TC with rustoleum and two years later they still look good. I roughed up the siding and sprayed two coats. Try a small area (like under the overhang) to see how it looks.
2000 Chev 1500 Silverado
1965 Airstream
Yamaha EF2800i generator
Prodigy
BIG RIG GUY
Milton Ontario
Sure you can paint your old trlr,any decent automotive paint will do. The Imron is alittle overkill, but it will last a long time. I painted a couple of old units the last couple of years and it sure did make them look sweet. Scuff pad, mask up and shoot color. No need for primer. If your caulking first, make sure your using paintable caulking.
Painting the brother in laws Newmar fiver this coming March, has some fading issues and needs a little bodywork here and there. Problem will be deciding on graphics after it is painted, maybe paint on our own graphics????
There is a method to the madness, disturb the method and the madness begins.
jrp26789
wyoming mn
you may want a self etching primer for aluminum. Then you will have less chance of peeling. Unless the 1st coat is in good shape then scuff and paint away. Quality products always make for a better result.
2006 Dodge 1500 4x4 4.7 5sp 3.96 gears
2005 Crossroads Cruiser CF25RS
If it is fun the State of Minnesota will try to outlaw it.
