RV.Net Open Roads Forum: Toy Haulers: Battery Chargers
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > Battery Chargers
BobWanderer
Perris,Calif,USA
Posted: 01/29/08 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a small battery charger and want to mount it inside Our T H.
I would like to wire it in so that it charges the battery when the genny is on or hooked to shore power. Its one of those 15A automatic chargers that supposed to drop down to a trickle and maintain the charge and prevent sulfation.
I don't like to leave it plugged in all the time, seems like the stock converter just boils the fluid out of the two 6 Volt Batteries.
I don't want to spend much on replacing the converter, as We plan to move up to a 5 er in the next year or so.
What next?? I ASSume I need to find a place where 110 V and 12 V are available and splice it in.
Any suggestions will be appreciated, and THANKS
Moderator's Edit: Moved to Modifications & Accessories category.
* This post was edited 01/30/08 09:27am by an administrator/moderator *
Bob J
2008 GMC 2500HD 4X4 Dizzle CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
MEMBER AMA and CORVA
nny12972
NY
Posted: 01/29/08 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
I WOULD NOT SPLICE IT INTO ANYTHING! Too easy to forget it's plugged in----don't connect a charger to your converter terminals---same reason!
....if you need to charge, plug it in and connect it to the battery (batteries) when you set up.
If you have more than one battery connected in parallel, the charger connection should be positive/hot charge lead to positive/hot battery terminal on the first battery...negative lead to the negative terminal on the OTHER battery. And still watch your battery acid closely! Not all 15A chargers are created equal!
J
NTORACN
Moreno Valley
Posted: 01/29/08 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
My RV has "converter/charger under the table seat that has a prewired 110V outlet just for this charger. Anytime the coach see's 110 Volts, it charges the coach battery. I also have a small 5 watt photocell charger on top of the roof A/C that always keeps the battery topped off. My coach also has a relay that connects the coach battery to the engine's charging system, only when the engine is running. You could also do this with your trailer. It means I can camp at Ocotillo for several days on one battery without worry.
mapguy
Puget Sound
Posted: 01/29/08 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Bob,
What converter do you have now?
A Progressive Dynamics 45 amp charger with wizard is available most any time on ebay
for less than $130.00 delivered. Yes it is more money than a small vector charger but will not be a hindrance when trying to sell or trade the trailer down the road and it will treat your expensive batteries right!
map guy
* This post was edited 01/29/08 03:00pm by mapguy *
bkirkpatrick
Brea / Orange County, CA
Posted: 01/29/08 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Bob, splice into one of the 15 amp plugs and run wire to a new outlet that you put close to your batteries. You can even mount a light switch to make the plug hot only when you want it to.
Raptor - Modifications
badbrad60
San Jose
Posted: 01/29/08 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Xantrex 1000 inverter/converter. Although it has a 3 stage charging process, it doesn't know when to shut off. I put a smart basic remote and now when I see the batts are full I push the "charge" button and it turns off the charger while still having the shore power connected or the genny running. I put a solar panel that puts out a small charge for storage. It has desulphation built into it...In the winter the panel I have struggles to get a full charge, but the summer it should be able to do the trick. ~Brad
2006 F350 DRW
2007 Weekend Warrior FTL 40
2006 trx 450r
2001 raptor 660
2003 trx 250
2002 ltr 50
2000 yz250 (will be dearly missed)
2000 CR500 Sand tractor!
2008 KTM 450 XCWR
mikelab
Escondido, CA
Posted: 01/29/08 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
since you are getting a new rig in a year, just hook up the charger to the batts when you make camp. it isn't that big a hassle, and you can take the charger out when you need it. if that is too much a hassle for you, get a new converter. that way there is no hassle, the batts get charged correctly, and you won't take a chance of ruining your batts.
i use to mickey mouse stuff all the time, now i'm too old and too lazy! i use to live by "time is money". now it's "money saves me time".
Mike and Trina
2 Kids
'04 Chevy 3500 dually diesel
'06 Weekend Warrior SL 30' 5th Wheel
Reese 16K Signature Series Hitch
Honda CRF 450X
Honda TRX250EX Quad
Honda CRF230F
Kawasaki Mohave 80 Quad
Ocotillo Wells, Class of 1968
BobWanderer
Perris,Calif,USA
Posted: 01/30/08 02:00am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info, I will prolly just hook it up when needed.
I have a solar trickle charger, but seems like I forget to hook it up.
 > Battery Chargers
