RV.Net Open Roads Forum: Tech Issues: Carbon In Tailpipe
 > Carbon In Tailpipe
woolfy
Saint Charles Mo.
Posted: 02/04/08 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I'm seeing carbon in my tailpipe. Is this something I should be concerned about. We have a Class C M/H on a Ford E450 chassis with only 3,000 miles on it. Have seen other Class C's with no carbon in the tailpipe
Woolfy
2007 Itasca Spirit 31' Ford V-10
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Mark Twain
pbitschura
La Crescent MN
Posted: 02/04/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
As she breaks in, and you put miles on her, this too shall pass. You're burning some oil right now, and stystems are just cominhg together. After about 20k, you should see a difference.
1988 Mallard class c 24' Chevy chassis 350 cu gas.
Tankcar
Santee, Ca. USA
Posted: 02/04/08 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
HI!
What type of OIL do use? Referring to base oil? Not all the stuff they add to the oil.
I assume you have broke in the engine as Ford directed?
Ford are know to use oil. It varies from one QT. each oil change to one every 1000 miles.
I did own one! On some of the older motor(s) it was the PVC system was the culprit. Newer power plants not sure where the problem is.
My current puller is not having that problem. Gaser, V-10. Not a Ford. Its one of the other guy's. w/199,172m's (castrol 10w-30)since brake in)
Have a Great Day! Jim
Wherever I happen to park
Posted: 02/04/08 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
There are two things that look a lot alike, Burnt oil and carbon, If it is carbon it is a sign the engine has run rich, Now... This is NORMAL under SOME conditions (IE: Cold engine) so it is not the presence of carbon, but the amount, that matters
Alas, beyond that I can not comment. Not enough experience in this area.
usmohls2@yahoo.com
CA
Posted: 02/04/08 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Motor running a little rich, wonder what the exhaust valves look like? Use a good quality fuel & put your foot to the floor a freeway speed. This should blow her cleaner.
Dinosaurman
Piney Woods
Posted: 02/05/08 03:36am Link  |  Quote  |  Print  |  Notify Moderator
Reminds me of a Ford Ranger I had a few years back, started getting only 800 miles to the quart and the Ford dealership said it was "well within specs".
kaagee
Burlington Ontario
Posted: 02/05/08 07:24am Link  |  Quote  |  Print  |  Notify Moderator
woolfy.
It's probably rust ...LOL...have you added any oil?
At 3000 miles I doubt very much that you have a problem.
If you think you do...take it to your Ford dealer to check it out..
I have a V10 with 60000 miles on it..and it never requires topping up between 3000 mile oil changes...and my previous Ford MH with a 460 and 100000 miles never needed topping up either.
Use it and have fun!!
Ken
gperky
laguna niguel, ca
Posted: 02/05/08 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
My V-10 in my class A had a sooty tailpipe but didn't use any oil nor get poor gas mileage. At about 15,000 miles I wiped out the inside of the tailpipe and the soot has not reappeared in the last 3,000 miles. I think that the long exhaust system cools down the exhaust so much that the soot doesn't get burned out like it would in a short car system.
scbullis
Travis AFB CA
Posted: 02/05/08 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
gperky's explantion matches what Workhorse told me about black soot in my exhaust. The exhaust gases cool down in the long exhaust many of our motohomes have and leaves exhaust residue in the exhaust tips. Doesn't matter if it's Ford or Workhorse.
