RV.Net Open Roads Forum: Is using a quick release on H2O OK?
 > Is using a quick release on H2O OK?
djevans
Tennessee
Posted: 02/06/08 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Every water connection including the tank rinse systems, are quick connect including at the faucet. (although I do have to screw an adapter on the faucet) Our don't noticeably reduce the "volume" of water at all.
We do use good quality brass ones and we've had them for years.
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
texasbaskets
Frisco, TX
Posted: 02/06/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
I use them as well, and found that a "y" at the hose bib where you can release the pressure before disconnecting will keep you from getting wet..
Michael, Kay, Hans (our Mini-Schnauzer co-pilot) and Prissy (Hans' Malti-Poo co-pilot)
'05 Coachmen SportsCoach SE 372DS a.k.a. "Mana's Cabana"
Texans
Posted: 02/06/08 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Have used the brass ones for years. A couple of them started leaking a while back, soaked them in vinegar and they were good as new. Richard
Richard and Annell,
03 35' Dolphin (Workhorse W22), 02 4x4 Tracker,
Brakebuddy
Busskipper
Arnold,Md
Posted: 02/06/08 09:36am Link  |  Quote  |  Print  |  Notify Moderator
8 years with No Problem
Love Them,
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
MDX-FMCA--M&G Brake
States traveled in this Coach
John&Joey
Northern MN
(Baby it's cold outside)
Posted: 02/06/08 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Got mine from Wal-Mart. No problems yet. Makes hooking the hose into the bay much easier.
Clay L
Sioux Falls, South Dakota
Posted: 02/07/08 10:40am Link  |  Quote  |  Print  |  Notify Moderator
hwybnb wrote:
larry cad wrote:
I use one and no significant problems. However, you should be aware that these devices do cause a drop is available water pressure.
The pressure will always be the same on the RV side of the connection as it is on the outside.
That's true until you start using water in the RV, then there is a pressure drop across the restriction and the pressure in the RV will be less.
There is a good explanation HERE
* This post was edited 02/07/08 10:53am by Clay L *
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
