RV.Net Open Roads Forum: Toy Haulers: Hooking up
Search only in Toy Haulers
 > Hooking up
gouldc
Edmonton, Alberta Canada
Posted: 02/07/08 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have heard, and had it work for myself on occasion, that once the jaw closes, putting the truck into forward and lightly tugging on the pin will further close the jaws. Isn't all of this pushing and pulling pretty tough on the landing gears?
03' Lariat F350, 6.0L Short Box *SOLD*
04' Jayco Eagle 28FKS *SOLD*
08' FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
07' Keystone Raptor 3712TS PICTURES
Reese 18k Signature Series Hitch
RoadWarriorz
Anaheim Hills
Posted: 02/07/08 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
gouldc wrote:
Could be the wrong area to post but here goes.
I'm using a Reese Signature 18k. I'm having a heck of a time hooking up. Everything seems to go well, jaw closes and the handle retracts except not completely. The metal "flag" does not move completely and I'm unable to insert the safety pin. I then have to unhook, pull ahead and try the whole thing over again.
I'm wondering if I'm missing something simple here or do I have a problem with the hitch? Seems to me it's acted like this from day one. I've tried coming in with the nose of the trailer a little higher and a little lower, no difference. It's extremely frustrating!
I had the Reese Signature Series (18k) hitch and after a few hook-ups it seemed to get better. Like others in this post, I would just roll back until I am about a foot away from the hitch and then lower the trailer slightly lower than the hitch. I would just drive back and everything would work just find.
Now I went to a short bed truck with a PullRite Hitch and I am have similar problems. I am hoping with a few more hook-ups everything will work smoother. I feel the frustration!
The Greatest Wife
3 Kids
1 Puggle "Buddy"
2006 WW LE3105
2008 F-350 FX4 CC SB 6.4L Transferflow 50gal PullRite SuperGlide 18K
06 Polaris Ranger
Honda 90 TRX
E-Ton 50cc
CAT Mini Bike
Taboky
Nashua, NH
Posted: 02/07/08 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have same hitch. I found that I just had to push the handle in a bit and it snaps into place and flag moves out of the way.
Steve
'07 Raptor 3712
'08 F350 DRW Lariat crewcab longbed 4.10ls 4x4
'02 Kawasaki Nomad dresser
bjbear
Cold Lake, AB, Can
Posted: 02/07/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Don't have a Reese, but did have a similar problem with my Hensley T3. It was a small burr that had formed on the kingpin. Wasn't very large, but just enough to keep the jaws from closing completely. I ground off the burr with a dremel tool and have not had any problem since.
2003 Dodge 3500 DRW HO with:
Edge Juice
Banks Ram Air, Pac-Brake, Exhaust
ATS 5-star Torq Conv
ATS Hi-Perf 48RE Trans with Billet Input Shaft
Trailersaver T3 Hitch
2005 Komfort Karryall - 36 foot
2006 HD Electra-Glide FTHCI
2 - Kaw Brute 650i Quads
HUTCH45
NORCAL
Posted: 02/07/08 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
gouldc wrote:
"....Isn't all of this pushing and pulling pretty tough on the landing gears....?
Having your trailer wheels firmly chocked really helps out on landing gear strain when hooking/unhooking.
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 35' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
"PRIMO" The Boxer
gouldc
Posted: 02/08/08 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the input guys, really appreciated.
I guess I'll have to be patient and focus on finding that key height and take a close look at the pin itself. If all it takes is a little build up it could be easily missed. I think I'll replace my lube plate as well just to rule it out. Nothing more frustrating than playing theses games while hooking up in the pouring rain.
Oldbrat1960
Sacramento, CA
Posted: 02/08/08 10:27am Link  |  Quote  |  Print  |  Notify Moderator
Yup, I managed to bend the flag tab on an angled hookup. I didn't know it till the next hookup. I had to remove the head and check from the underside to clearly see the damage. I haven't had any trouble since I bent the flag lever back. I agree with the "hitch low" posters. Get the truck to squat when connecting for best alignment.
Pleasure in Playin'
ncmech
Wake Forest, NC, USA
Posted: 02/08/08 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Mine does the same. I hitch up with the trailer ~.5-1" lower than the hitch plate for some down pressure. Stop when the hitch firmly engages the kingpin. Push the handle in as far as it will go, and the flag sometimes is about 1/2 flag thickness from engaging. Lift the landing gear until the pads just float over the ground, then put truck in neutral, let it settle, set the brake and put back in park. Handle usually frees up a bit and flag drops no problem. Then fully retract the landing gear and stow the wheel chocks.
I use a lube plate also- doesnt really affect it, so save your $10 for beer....
2005 F250 CC Lariat 4x4 SB Diesel
2007 KZ 35PX2
Former 2000 Northstar Laredo SC
gouldc
Posted: 02/08/08 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
When you say 1" lower than the hitch plate, what part of the pin are you referring to, the bottom?
I like your thinking, you can't drink a lube plate!
Bellclan5
Camarillo, CA
Posted: 02/09/08 10:38am Link  |  Quote  |  Print  |  Notify Moderator
As said before you need to leave the trailer hitch lower than your truck, then once it is locked in, put in forward and pull forward (don't accelerate, let idle forward) in just about every owners manual it tells you to do this, next as said before put the truck in neutral and let it settle, you shouldn't have any problems from there.
If you are still having a problem I would take it to a reputable hitch dealer and let them take a look at it, you have something wrong with either you hitch or the king-pin.
Good luck
Ford F-350 V10 4X4 4" Lift
Vortex 325WTB FW Triple Axle
2003 Raptor 660
2006 Mongoose 250
2006 Mongoose 250
2006 Mongoose 250
2006 Mongoose 250
2006 Mongoose 250
Beautiful Wife
Two Sons
Two Daughters
One Grandson
Hooli in training
 > Hooking up
