RV.Net Open Roads Forum: Towing: Trailer Hitch Locks
Search only in Towing
Open Roads Forum  >  Towing
 > Trailer Hitch Locks
BarneyS
S.E. Lower Michigan
Posted: 04/14/08 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
You might want to take a look at Trimax locks They make some really good stuff! I just ordered a new SS locking hitch pin lock from them to replace my old, rusting bent end pin lock. It is a 5/8" pin that does not use a sleeve. The old one has worked well for quite a few years but has wallowed out the receiver hole on one side and is starting to rust and become worn. Time for a new pin and probably a new receiver as well.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
hot rod
muskegon,mi
Posted: 04/14/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
I use this
http://www.drawtite-hitches.com/products/Gorilla_Guard_2_5_16_inch_Coupler_Lock,63227
Graybeard
02, 2500HD, ext, 4x4, sb, 8.1, allison, 3.73, TransFer Flow 50gal.
30'Layton TT
bugup
Bellingham Wa
Posted: 05/08/08 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
I think I am going to forget about a coupler lock and use the Fulton wheel lock. Quick to put on, nice orange color, and fits like a glove. Also, don't have to worry about someone hauling it away on the chains. West Marine $49.
2008 Jayco G2 32 BHDS
92DakotaHD
Indiana
Posted: 05/08/08 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
I've got that pin receiver lock and that sleeve is on their pretty tight. It doesn't come off so easy. And Wally world has the set for $35.
1992 Dakota 2WD 5.9L V8 (NOT Stock)
Headers, FMS Injectors, Ported TB, MP PCM (not good for towing),
2005 Chevy Tahoe Z71- Bermuda Blue, A/T Revo 265/70 "E"
Prodigy Controller
08 Passport 24RB, YAY SPACE!
Gone Racing!
A newbie, any tips please share!
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/08/08 11:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have the coupler latch lock in the etrailer.com picture, a 5/8" version of the hitch lock in the picture, and another master lock model kinda similar to the coupler nose lock pictured. They all work fine for me with a squirt of light oil or wd40 in the mechanism ever few months.
The hitch lock I like best is the DrawTite j-pin model that has a threaded nut on one side that tightens up the slop in the hitch. I use that one most. My reciever wasn't j-pin compatible so I drilled a hole in the side of it and now it is.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
