Kenney B
Redding Calif.
I tow a 98 wrangler and am trying to locate a cover for the front of my jeep , any ideas?
Corkey05
Washington State
You mean like this one, .... (Click Here) - coastlinecover.com
2008 HR Endeavor PDQ - Blazer 4 Down
FMCA F374292
Shotgun
CA
go to any 4x4 parts house and ask for a bra
Hunting is not a hobby. It is much more life sustaining than that.
Dale-pilot, Jeanette-co-pilot
Electrician since 1978
2003 30' Sprinter 5er
2001 Dodge CTD
driveby
Vancouver BC Canada
it it is for used when TOAD the you could also look at the Protect-A-Tow
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
JohnnyT
Goshen New York
Moved from class A forum
BigRigRVing
formerly CA
We have not had any issues with windshield or front of jeep since we put the 4" lift kit in ours, prior to that, lots of chips. Not a fan of covers or bra. Tried protect-a-tow, it worked, kinda, saved the front of jeep, but the rocks that hit the plastic protector, bounced and hit the back of motorhome. Which cost more to paint?
Gary & Cheryl and our chocolate lab named Caddy
2005 Newmar Mountain Aire 4304 w/ Blue-Ox Sports Lift
2006 Jeep Rubicon
HD 2006 Softtail Deluxe
www.BigRigRVing.com
wilanddij
CA Desert
I'm pretty much with DiverGary, but my Wrangler hasn't needed a lift kit. I simply put 31" tires on positive offset wheels, and that (along with the stock rear wheel mudflaps and a rock guard from CW) seems to keep it free of rock chips.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
legal-eagle
Canada
Quote: We have not had any issues with windshield or front of jeep since we put the 4" lift kit in ours, prior to that, lots of chips. Not a fan of covers or bra. Tried protect-a-tow, it worked, kinda, saved the front of jeep, but the rocks that hit the plastic protector, bounced and hit the back of motorhome. Which cost more to paint?
I use Protect-a-Tow and nothing can bounce back and hit the coach as it stretches between the coach and the towed under the tow bar. Sounds like you had the plastic shield gizmo that mounts on the tow bar in front of the towed and does deflect stones back to the coach. Try Protect-a-Towit will protect the jeep, the coach and the tow bar.
wanderer72
Canada
I have been very happy with Protect-a-Tow, been using it for a few years now and wouldn't tow without it! We're looking at getting a new toad and the wrangler was an option, any pro's/cons on towing a wrangler?
"A mind is a terrible thing to waste and a waist is a terrible thing to mind."
Deb and Ed M
SW MI, USA
wanderer72 wrote: I have been very happy with Protect-a-Tow, been using it for a few years now and wouldn't tow without it! We're looking at getting a new toad and the wrangler was an option, any pro's/cons on towing a wrangler?
In the for-what-it's worth category: Wranglers are SuperToads!! Plus they give you sightseeing options (offroading) that most cars can't; and on nice days, they become "convertibles"...LOL!!! Access to wiring; and running stuff from the cabin to the engine compartment is super-easy because there are rubber grommets in the firewall you simply pop out.
As others have pointed out, the higher clearance of the Wrangler seems to keep them from getting all stone-chipped as toads. Mine hasn't suffered any chips - we just have a "hula skirt" on the MH.
If you are looking for a used vehicle, the '06 and older Wranglers are the easiest to tow - the first click of the key unlocks the steering column, but doesn't turn anything "on". My understanding is that the newer ones need to have a fuse pulled (as do most vehicles). Not a "biggie" - but we decided to buy the '06.
Deb
