RV.Net Open Roads Forum: Class A Motorhomes: Egg smell mystery
 > Egg smell mystery
subtroll
Hayes, VA
Posted: 02/11/08 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Our MH is resting for the winter in its barn next to my workshop. Outside temperature this morning in Virginia was 26F but inside the MH barn its 46. As I opened the door this morning there was a strong "egg smell". Not the unpleasant rotten egg smell but more like the sulfur smell while preparing deviled eggs. The smell is not inside the coach only inside the area surrounding the coach.
My inverter is always on but I don't smell anything near the battery compartment. My gray and black tanks are empty. I had the coach out last week to get a new washer dryer and slide topper installed.
So far I haven't been able to locate the source. Any thoughts or suggestions?
2004 National Tropi-cal Sterling 396
2003 Jeep Liberty
tom_kat
way upstate new york/lake george area
Posted: 02/11/08 10:47am Link  |  Quote  |  Print  |  Notify Moderator
check your batterys sometimes when they go bad you get that smell ,check the water level you might have fried one or it may have shorted out inside the battery.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
grinder
Courtenay, British Columbia
Posted: 02/11/08 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, just don't light a match!!! Could it be a LPG leak from an external line ???
Ted
Courtenay, BC
TheDieselPusher
Agua Dulce, CA
Check to see if your fridge is working. Could be the ammonia? that they use for cooling, your cooling unit could of leaked. Your fridge will not cool.
Jim and Christina
2005 Sportscoach Encore
Saturn AWD VUE Toad, Brakemaster
ArchHoagland
Clovis, CA, USA
Posted: 02/11/08 10:52am Link  |  Quote  |  Print  |  Notify Moderator
I'd check the water levels in the batteries. All of them...coach and chassis.
The only other egg smell I have had experience with comes from the water heater but that doesn't show up till you run the hot water.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison transmission
6.9 MPG based on a 6,000 mile trip around the U.S.
US Gear Toad Brakes
JFG
TN
Posted: 02/11/08 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Batteries outgasing will smell this way. Is your inverter working correctly... not overcharging. turn inverter off for a day and see if smell goes away. Propane has a unique smell, not exactly like eggs, but still a smell. Close your propane valve and see if it goes away. Do you have any natual gas in the barn..heaters, etc? Natual gas smells more like eggs. pilot lite could have gone out.
Fred
bwtrump
Still no discounts for
Posted: 02/11/08 10:57am Link  |  Quote  |  Print  |  Notify Moderator
When our propane gets very low, we get a smell somewhat like what you are describing. Don't know why. . . .
Bryan and Peg, 3 kids IAFF Local 795
2008 Wildcat 28 RKBS
2003 Dodge 2500 quad cab Cummins 5.9HO
Husky 16K slider
Alex--Great Dane
Bull Mastiff--Sebastian Pierce
getinoutofmissouri
missouri
Posted: 02/11/08 10:59am Link  |  Quote  |  Print  |  Notify Moderator
my moneys on the batteries. it happened to use last month kept smelling something took a couple days to figure it out. one coach battery was almost dry tried to fill with distilled water but it was to late replaced both batteries.
crashpilot
Green River, WY
Posted: 02/11/08 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Just a thought... Could you actually have some rotten eggs from last summer that you forgot about?? They too smell like rotten eggs. LOL
Straight Board -
2008 Chevy 4X4 Z71 Crew Cab K2500HD LTZ Duramax/Allison
2005 Jayco JayFlight 31BHDS
2007 Kawasaki BF 650 4X4i Camo (mine)
2007 Polaris X2 500 EFI Deluxe (hers)
The mountains of Wyoming as my backyard.
Powder River, Let 'er buck!
Jim & Joan
Milton, WI
Posted: 02/11/08 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
If it isn't batteries, I would flush the entire water system including fresh water tank as water can sometimes cause like sulfur. Even though you drained both tanks the smell could still be there coming from the vent
 > Egg smell mystery
