RV.Net Open Roads Forum: Tow Vehicles: Storing F250 diesel for extended time
Search only in Tow Vehicles
 > Storing F250 diesel for extended time
fearnofish
Waterdown, Ont, Canada
Posted: 02/11/08 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hi, I have just picked up a new job that comes with a company car, and my wife has a company car so we will be parking our F250 all winter, and in the Spring, Summer and Fall, it will only get used on weekends when I go fishing or, when used on our 3 weeks of RV'ing. Is there anything I should do when not using it? Is this going to be hard on the engine? Any suggestions would be helpful. Thanks. Seems like a lot of truck just to park and occasionaly tow my boat but we have no choice, company vehicle is a car.
Jason.
Jason and Mary Jane
2 Brittany Spaniels, Ranger & Molly
2006 Montana Fifth Wheel 3295RK
2004 F250 Super Crew Lariat Diesel SB (Sweet!)
colliehauler
Mc Pherson KS USA
Posted: 02/11/08 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I only use my 04 F-250 Diesel for towing of a summer. I just park it with some additive in the fuel and a full tank.
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 02/11/08 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
From a Diesel Engine Book.
"To start with if you put your Diesel truck in storage it's a good idea to remove the batteries and put them in storage too. When you're removing the batteries always remember to remove the negative terminal first. Clean the batteries with a 50/50 mixture of baking soda and water if necessary. Store the batteries in a cool dry place but not where they could freeze. Batteries in storage will loose their charge. Check the state of charge every month and charge batteries that are at or below 80 percent state of charge.
Check and fill the water levels in all batteries that are not maintenance free. Check the electrolyte level and add distilled water if necessary.
Charge all batteries as required. A discharged or partially charged battery will freeze much faster than a charged battery.
Remove and clean all battery terminals and posts. Spray the terminals with terminal dressing to protect against corrosion.
If you plan to start the unit while in storage, and to periodically plug the unit into shore power leave the batteries in the unit. Plugging it into shore power once a month for about eight hours will keep the batteries topped off.
If you put the unit in long-term storage; remove and store the batteries where they will not freeze. In either case keep the batteries charged.
During short-term storage, start the unit monthly and run it with the dash air on for at least 30 minutes.
Fill the fuel tank prior to storage and add a fuel stabilizer. Run the engine and the generator long enough for the stabilizer to get through the system. Follow the manufacturer's directions.
Change the oil and oil filter on the engine storage. Acids accumulate in used oil and can corrode engine bearings.
Check the engine radiator for the proper concentration of antifreeze. Consult your owner's manual for the correct type of engine antifreeze. Drain, flush and refill the system every two to three years.
Drain the windshield washer reservoir or add the appropriate antifreeze solution to prevent it from freezing.
Perform full chassis lubrication prior to storage.
Now your Truck is truly winterized and hopefully you won't experience any problems when you perform your spring maintenance checks next year.
a_flyfisher
PA and MT
Posted: 02/12/08 02:10am Link  |  Quote  |  Print  |  Notify Moderator
I also read on one of the Ford truck forums that just prior to doing the items you mentioned that you should run the engine for a few minutes at a moderately high RPM (I don't remember the exact specifics).
a_flyfisher
F550-4X4
Cloverdale, IN, USA
Posted: 02/12/08 02:26am Link  |  Quote  |  Print  |  Notify Moderator
I've been parking mine for the winter for years. I go out about once a month and start it up to keep the batteries charged. I usually drive it back and forth in the driveway a few times just to move some transmission fluid around but that's it. So far I haven't had any problems.
Good luck and happy camping!
2000 F-550 4X4 Super Hauler Conversion
2004 Wilderness Advantage AX6 38 Ft. Quad Slide Fifth Wheel
1993 Chevy 2500 Suburban 4X4 7.4L
1999 Maxum Marine 2100SR 5.7L
2004 Jaguar S-Type 4.2L V8
2006 Jeep Liberty Limited 4X4
Obviously not badge specific!
Dave H M
IL
Posted: 02/12/08 06:41am Link  |  Quote  |  Print  |  Notify Moderator
What do you think the thousands and thousands of diesel farm tractors get for tlc during thee winter? Just a thought.
If I drug all my batteries from the barn into the house for the witer, I would probably wind up falling over one of them or getting in a fight with the wife.
See if the operators manual has any stuff on long range storage, a lot of them do.
Come to think of it, my powerstroke may get kinda lonely and cold in the winter
viper48
Asheville, North Carolina
Posted: 02/12/08 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Hi fearnofish, I to have a company vehicle and my 3500 Chevy duramax dually does not get driven a lot until summer pulling the 5er. I try to at least take it out once a week and drive it at least 30 minutes. I have done this for the last 2 years and have had no problems. As far a storing one for several months I do not believe that it would hurt it but I would remove the batteries.
2006 30' Forest River Flagstaff Fifth Wheel Model 8528BHSS
2002 Chevy Silverado 3500 LS Crew Cab Dually 6.6 Litre Duramax/Allison 4x4
2007 1100 Honda Shadow Spirit (Mine)
2001 1100 Honda Shadow Aero (Wifes)
Our Camping Photos
riddellr
Belleville, IL, USA
Posted: 02/12/08 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
I mostly use my F-250 in the summer to pull the boat and/or camper on weekends. During the winter months I simply drive the truck to work (10 Miles) once or twice a month. I have not had any problems doing this for the last two trucks.
txtowman
central texas
Posted: 02/12/08 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
I just park mine since the plastic fuel tank won't rust, my farm tractors go for months at a time with no adverse effects other than low batteries. had both tractors at least 10 years so thats a decent track record.
Wannabe-be-fulltime. Me & Madison(Chihuahua)
76' Sunflower 16'
96' Dodge 3500 DRW ext CTD 5 speed
1 Honda EU2000 gen
4 AGM batteries 468 amp hours
1000/2000 inverter/charger
