DianneOK
Donnelly, ID
Make it a true big rig friendly park/cg and we will come to you, no matter where it is Might even consider working for you
Dianne
Donnelly, ID
DataStorm
HAM WB6N (Terry)
2005 Teton 39' Frontier Grand
2003 Freightliner FL60
Life Member Good Sam
Escapees
Geocache..."RVcachers"
RV net Blog
AndreC
Northern VA
The biggest advantage of owning your own business, is that you get to pick the
50 to 60 hours a week that you work.
Also, if your going to be open year round, when will you be able to travel in your RV ?
Andre
2005 Allegro Bus
WTTCS
freedom , U.S.A.
Let's see, would I consider owning an rv park ???
After years of reading this forum and others pretaining to rving, and traveling the country , I thought about it one time...............
for about 1 second!
Wingnusa
Scott and Brenda Albuquerque, NM
Brenda works in the park we're staying at for now and we both agree that we need more of a life than this. No thanks for us but if you decide to do it....good luck!!
Scott and Brenda Schnelle
Olivia and Jasmine, Mini Schnauzers
2006 KZ Escalade 36CKB
2006 GMC 3500 D/A(LLY), CC, LB
Fulltimer Class of '06
Lifetime Good Sam's members
Lifetime NRA member
USCCA Member
Amateur Treasure Hunter
Amateur Banjo Player
sportrac
Canada
At the drop of a Hat.
Paul & Kathy
Canada
08 F350 Superduty DRW Power Stroke 6.4
07 Cedarcreek 37CKQS
04 Explorer Sportrac
07 Mirage 5x8 Cargo Trailer
wip
Manhattan Kansas
Make sure you aren't "buying a job." That is, make sure you get a return on investment in addition to your salary. Otherwise you are better off getting your salary from someone else and investing your money somewhere where it does bring a return on investment.
crc
trkrhelp
On The Road
Generally the ROI guys seem to overlook that value of SATISFACTION - so when you're calculating your ROI don't forget to factor in the satisfaction that comes at the end of the day from looking at what you've accomplished with your own sweat and tears. It's something that you never get from working for someone else.
John Ewing
2007 Allegro Bus 42QRP ("TisIt")
2005 Sportster/HydraLift ("Dinky")
2002 Miata toad ("Mellow Yellow")
www.jandse.com
FMCA 104106
What goes around comes around - always treat others the way you'd like them to treat you.
INDIAN CREEKER
Chasing the 70s
One thing to offer. SNAP OUT OF IT!! Now get back out there and enjoy life with the rest of us. Dave
"06" Cedarcreek 36RLTS, "06" Chevy 3500 Duramax....THIS IS OUR HOME!
elh0146
Sioux Falls, SD
WadenCeeJay wrote: Would YOU consider it?
NO, absolutely not!
Unless you have a seasonal campground, you'd be tied to it 24/7/365...don't count on being able to find competent help who could run the place while you were gone.
Then there's the fact that you'd have to deal with the public, not always a pleasant thing.
restlesswind
Fulltime
How much fun....?None...more fun traveling an staying in the park for just a few days or weeks then moving on..
Hichhiker DA
04.5 Dodge TD SRW
Fulltimers
