RV.Net Open Roads Forum: Toy Haulers: Questions about 5th wheel toy haulers
Search only in Toy Haulers
 > Questions about 5th wheel toy haulers
silverlakerider
Nevada
Posted: 02/14/08 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I'm new to the RV forum, but first off thanks to Y-guy for posting all the manufactures of Toy haulers. I'm thinking about buying a 5th wheel toy hauler and have done searches but can't seem to find exactly what I'm looking for. Maybe you all can help.
I'm looking for a toy hauler with a 20 foot cargo area-big enough to hold 4 snowmobiles. Since I'm sleddin', what 5th wheels have a "winter package" ie: heated basement, dual pane windows, good insulation etc. And lastly, what size truck do I need to pull a big triple axle trailer? Thanks in advance.
lincster
Mesa Az
Posted: 02/14/08 07:44am Link  |  Quote  |  Print  |  Notify Moderator
20' of cargo is going to have to be around a 40' trailer, no separate garage.
F450 or bigger is what you need to haul that much weight.
Sleds are heavy right?
2006 F350 PSD CC 4X4 Dually w/Tow Boss package to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
skidoomxzx
Alaska
Posted: 02/14/08 08:01am Link  |  Quote  |  Print  |  Notify Moderator
We haul our sleds in our Raptor all winter but it will only hold 3 with a 12 ft garage. Before we got a screaming deal on the trailer I was going to have one built byTrailer. This way I could of easily hauled 4 sleds and had the trailer insulated and built the way I wanted it, plus it would have been lighter than what I got.
TEAM LEADER
OCEANSIDE, CA
Posted: 02/14/08 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
You should look into a c-class diesel or class-a pusher with an enclosed car hauler. The water is going to do damage in the long run to a toybox hauler. I know its easier said than afforded though.
03 Duramax Crewcab, 4x4, BullyDog Programmer, 4" Magnaflow exhaust, Air Lift air bags.
05 31'LE Weekend Warrior 5th Wheel
Watercraft: Kawi 750 and a Kawi 1200STXR
dirt: Crf 50, Cr125, Cr250, Suzuki Ozark, Yamaha Blaster,
Suzuki Samurai.
r1Mk
modesto, ca
Posted: 02/14/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Four sleds in a toyhauler! U gunna need a BIG toyhauler.
That will limit you to an open model (no separate garage) and water will roll around onto the carpet, lino and under your cabinets as the snow melts off your tunnel. You might also run into width problems as you get up to the kitchen cabinets and such.
A TH this big is going to be a pain in the @$$ at Hope Valley. Another option, if you have a long bed, is getting a slick lift and putting two on the truck and two in a travel trailer TH. I think if you have a short bed the overhang out the back of the bed is too much for towing a trailer (unless you can make your trip without turning ).
'06 GMC 2500HD D/A 4X4
'07 Crossforce 33MK
Winter Arctic Cat 900 1M, Polaris 700 RMK, Polaris 550 RMK
Summer Honda 300 EX, Yamaha 80, Polaris 50
WhitehouseLV
Formerly Las Vegas, Now Big Sky State - Montana
Posted: 02/15/08 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
you could fit three in a 12' garage. If you want to get four you'll need to build something like this I've been sledding w/my 3612 Raptor. My experience is that the TH is nice when the weather is cooperative and the roads are good. Those two things usually only happen towards the end of the season when the snow isn't all that great. Although I'm thinking of dewinterizing the Raptor tomorrow and go sledding. It is suppose to be in the high 30s. Truthfully though a 4 place snowmobile trailer works so much better and is a lot less stressful.
Traveling Whitehouse
2006 Keystone Raptor 3612DS
2004 Chevrolet Silverado 3500 CC LB DRW Duramax LLY 4x4
Reese 20K Hitch
Prodigy Brake Control
2007 Honda Rincon & 2000 Honda Rancher
Bellclan5
Camarillo, CA
Posted: 02/16/08 01:13am Link  |  Quote  |  Print  |  Notify Moderator
The only toyhauler that I know of today that has a heated under belly is the Fusion, awesome trailer, they also have the vented attic that helps keep out moisture as well.
Good luck
Ford F-350 V10 4X4 4" Lift
Vortex 325WTB FW Triple Axle
2003 Raptor 660
2006 Mongoose 250
2006 Mongoose 250
2006 Mongoose 250
2006 Mongoose 250
2006 Mongoose 250
Beautiful Wife
Two Sons
Two Daughters
One Grandson
Hooli in training
silverlakerider
Nevada
Posted: 02/16/08 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks a lot for all of your replies. I love these forum sites. So much info. to be gained. A 4WD class C with a trailer without trailer brakes would be the ultimate combo, but that's a lot of coin. But if there isn't a stock toy hauler big enough and I have to have it specially built than that will probably be a lot of coin as well. Thanks again for your help.
Ed
lightfoot
Cary, Illinois
Posted: 02/19/08 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
check Rage'n, they have a 5er that has 22' of available storage space. The model is BH4005
2005 Rage'N SS2400
'94 Honda GL1500, 230,000+ mi.
2005 Chevy 2500HD ext cab, 8.1V8, Allison Trans and full trailer package
