RV.Net Open Roads Forum: Toy Haulers: adding 2nd AC to Raptor 3712TS
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > adding 2nd AC to Raptor 3712TS
cm5217
Mechanicsville Maryland
Posted: 02/15/08 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
has anyone added the second AC to the bedroom on the raptor 3712TS??? I was just wondering which ac to buy and how to wire it into thermastat??? I know the power is already pre wired but is the control wires there?? also need info on adding the heat strip on my existing AC??? does it work with the stat or just from the ceiling unit??? Thanks for all the info in advance
2003 GMC sierra Duramax Allison 3500 Dulley
2007 Keysonte Raptor 3712TS
2003 Harley Davidson Softail Night Train 100 Year ann.
2002 Polaris Sporstman 500HO
Y-Guy
Tri-Cities, WA
Posted: 02/15/08 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
I am pretty sure you will need a different thermostat, the only wires that the run are for the power. A 13k AC is probably fine, though you could get away with an 11k - but a bit more won't hurt. We only had one in ours and did fine on all but the very hottest days.
Heat strips for the most part are a waste of money IMHO. You can buy a good ceramic heater that will put out a lot more heat for less money and less hassle.
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
Raptor38
Lake Placid, Fl.
Posted: 02/15/08 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to add one to my Raptor before summer. There have been several occassions where it was needed and I wish I had it. My buddy added one to his when he purchased it, 13.5 Coleman. All I can say is, ICEBOX...
07' Chevy C4500 Kodiak Chariot Conversion
07' Keystone Raptor 3612
07' Yamaha Rhino 660SE
05' Honda VTX 1300C 240 rear
reactancexl
Tempe, Az, USA
Posted: 02/16/08 09:26am Link  |  Quote  |  Print  |  Notify Moderator
I believe the thermostat is on the AC itself. I know I need one also. thx
wild bill
Mira Loma, Ca. USA
Posted: 02/16/08 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
The thermostat on my ad on a/c is in the unit itself.....works great! Be sure to check the circuits when you hook it up...the factory had both a/c units of the same circuit breaker....moved some wires around in the pannel so that both would run at the same time.
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000,Sand Rail 02 Nightrain,ST4s KLR650,ll00RT,AOPA BMWMOA,EAA,HOG,TDR,NRA,FCSA
HeatAnywhere
Manti, UT
Posted: 02/16/08 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I did the very mod you are talking about last summer. Great addition when at the dunes in 90 degree or hotter weather. I used the Coleman 13.5K Mach unit and couldn't be happier. Instalation was a snap once the unit was on the roof. The thermostat is built right into the unit itself and has worked just fine for me. As already mentioned, the only wires pre-run are for power.
**Never get so busy making a living that you forget to make a life**
04.5 Sierra 2500HD CC SB Duramax/Alison plenty of mods
07 Raptor 3712TS and lovin' it
07 Grizzly 660(4x4)
04 Grizzly 660(4x4)
02 RM250 bike
05 90cc Predator
05 KX50 bike
