RV.Net Open Roads Forum: Technology Corner: TV Interference - DTV
 > TV Interference - DTV
Wherever I happen to park
Posted: 02/16/08 11:47am Link  |  Quote  |  Print  |  Notify Moderator
You say it's fuzzy when you went to set the signal strength. This is a clue, the page you see when you are on the antenna pointing page is locally generated, (Means it is generated by the receiver, NOT something you get from above) so if that page is Fuzzy your problem is between the receiver and your television.
Now: Tell me about that link. How is it hooked up Are you using direct, composite video feed? or RF, does the RF cable from the sat receiver go direct to the TV or through a switch or switch network. If a switch what kind Are there any splitters or other devices between the receiver and the TV
What channel is your TV on, and does that channel have a station in your area (And is the receiver set to the same channel)
From the answer to these questions I can advise more
ShapeShifter
Buffalo, NY
Posted: 02/16/08 11:50am Link  |  Quote  |  Print  |  Notify Moderator
donscomp wrote:
before I even got a signal and the receiver was at the signal strenth screen it was fuzzy.
This comment makes me almost positive it is a connection issue between the receiver and the TV. I'll bet you find a loose connection or a cable with a broken ground.
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
donscomp
Camarillo,CA
Posted: 02/16/08 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
You say it's fuzzy when you went to set the signal strength. This is a clue, the page you see when you are on the antenna pointing page is locally generated, (Means it is generated by the receiver, NOT something you get from above) so if that page is Fuzzy your problem is between the receiver and your television. I Agree
Now: Tell me about that link. How is it hooked up Are you using direct, composite video feed? or RF, does the RF cable from the sat receiver go direct to the TV or through a switch or switch network. If a switch what kind Are there any splitters or other devices between the receiver and the TV... From the DTV box via coax to the multi switch box. TV2 has a splitter and feeds the Bed TV and Ext. TV jack. Ooops. Forgot something. There are 3 coax connectors in the wall in the cabinet. 2 are incoming. 1 from exterior (ie for portable) 1 from roof. And an outgoing that labeled TOO switch box. Which is lame really as it just makes a loop through the side of the cabinet and comes back in the rear. Then into the Sat on the switch box. I tore those 3 jacks apart also.
What channel is your TV on, and does that channel have a station in your area (And is the receiver set to the same channel) Everything set to channel 3.
Figured "after the race I would try to bypass the switch box and go right into the front TV. If THAT clears it up? That would tell me it is in or around the switch box.
**2006 Monaco Diplomat 38PST**
** Wish we were Fulltime **
** Friends Of Bill W. **
**GIT-R-DONE!!**
2oldman
WA
Posted: 02/16/08 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Has this 'switchbox' ever worked? And yes, if it clears up of course it's in the switchbox.
donscomp
Camarillo,CA
Posted: 02/16/08 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Just bypassed everything and came from the DTV box to the main from TV into the back of it and it still does it. Leeds me to now believe that it is an internal power or interference problem.
Errrrrr MAYbe just around this park but I dout it. Always been clear here before. : (
dennis1949
Decatur, Alabama
Posted: 02/16/08 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
try a different coax. Had the same thing and mine had gone bad
Dennis Carpenter
Decatur Alabama
2001 3/4 ton Dodge Diesel
2008 Cardinal 31 RK LE fifth wheel
jvann1
Whidbey Island, Wa.
Posted: 02/16/08 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
This is a good suggestion. I have seen a few cases were the shielding around the cable has gotten wet, acts as a water wick and will very rarely, but can cause interference. But have a strange feeling that the power supply for that switch (if its an electronic switch), just might be bad. Would suggest subbing cable from antenna right to converter for system. OOPS sorry, it appears that you might have already done that. If you are still getting interference, is from an outside(radiating) source or from something running in coach.
2005 Ford F250SD
V-10 torqshift, tow command
2004 Komfort
"April" the attack cat!
donscomp
Camarillo,CA
Posted: 02/16/08 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
It was a coax out of a bag. All other ones I pretty much wrenched down behind the switchbox and all. Something else. The signal coming out of the DTV box when at the house is clear. In case someone was wondering.
When I said "It was a coax out of a bag" that was to the TV by passing the switchbox. I'll try replacing the one from the dome to the DTV box..........
No that didnt help. Then I relized that I had tried it once without incoming at all attached and it still did it. Duhhh. HAS to be some sort of interference.
Thanks all BTW for handing out suggestions
* This post was edited 02/16/08 03:02pm by donscomp *
SCR
Full Timer - I'm really not sure where I am
Posted: 02/16/08 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
You may want to head over to DBSTalk register (it's free) and post your question under the appropriate receiver type. There are some very knowledgeable friendly people on the forum.
s.
donscomp
Camarillo,CA
Posted: 02/16/08 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
s.
Been there many times. Donno how much that would help though. It works fine at home.
Havnt really seen where anyone talks about dishes in the RV's though.
But I'll check.
