RV.Net Open Roads Forum: Truck Campers: Happijac Clicking Problem?
 > Happijac Clicking Problem?
BigBlueDiesel
New Mexico
Posted: 02/16/08 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
I was in the process of cleaning up my TC and doing the maintenance on the Happijac 4500 jacks. Lifted the camper up no noise, started to bring the camper down and I hear my front jacks clicking or popping till it was all the way down. My rear jack were fine no noise. I took off the covers on all 4 jack they all look the same. Can some one tell me how to fix this problem.
Bryce & Sarah
2005 Bigfoot 2500 9.4 ---Sold
2003 F-250 Crew Cab SB 4x4 Diesel
wabbitman
Horsham, PA
Posted: 02/16/08 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Did you have the motor heads engaged? I can't remember if the lever has to be fully up or down to have the motors engaged. Maybe when you were doing maintenance, you moved one.
wabbitman
Chevy Silverado 3500 HD ext cab 4x4
Vortec 6.0L V8 gasser
6 Speed HD Auto Trans
Z85 Handling/Trailering Package
HD Locking Differential
Bigfoot Truck Camper 25c10.4
Wife and Gary - Lab/Greyhound Mix
Days Camping in 2008 = 22
Solarfry
Ft. Lauderdale, FL
Posted: 02/16/08 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
My camper electric jacks have clicked since new. I believe it is normal. It is the pawl that keeps the whole thing from unwinding.
We unload the truck from camper everywhere we camp. It sits happily on the ground and goes back on top when we leave.
04'Chev 2500HD 9200GVWR ExtCab LongBed 6L GAS tow pack
04' Lance 815, CP, AC, FF, MW, RE, ElectAtwoodjacs, loaded.
13.2mpg/w TC @ 55MPH tow'g 15' boat, 12 mpg @ 65-69 mph.
10@70mph. 8@75. Stock over 26k miles. All mileage before ethanol mandate in FL.
54suds
adk mts.
Posted: 02/16/08 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
the clicking is from a overload torque clutch built in to top gear assembly ,if you take the gear cover off there will be a nut on top of a stack of gears this is adjustable by tighting the nut very little ,No more than 1/8 of a turn,each time "Warning" overtightning may cause damage.
05 Ram xcab drw 4x4 4.10... 06 Bigfoot 25c10.6e....
DonCurley
La Sal, Utah
Posted: 02/16/08 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Mine only get that ratcheting/clicking sound when you have essentially the entire jack fully drawn up into the outer square tube. I have gotten better at anticipating this point and stop just a hair short of that.
-'07 Dodge 3500/QC/SB/SRW/4x4/6.7L CTD/6-spd auto/35" Toyo M/T's/Ride-Rite air bags/RS9000XL shocks
-'07 Apex 8 fully optioned w/220W solar/2 T-145's/2KW Prosine/Honda EU2000i/Tundra fridge/AC/etc
-'00 Jeep Wrangler TJ 4x4, highly modified w/5.9L Magnum V8
jma
Edmonton
Posted: 02/16/08 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
I had this happen to me on a camper many years ago. If it is the same problem that I had you need to feel the temperature of the gears. Touch the gearing and if it is hot (like really hot) then you have a major problem. I had this happen on two jacks and the camper almost tipped over because I was not paying attention. I got use to the clicking sound and the gearing actually seized and was not working (still made clicking sound) You need to either replace the complete gearing or at very least do a major cleaning and lubrication. I removed all the gearing so the jacks could not be manually operated and the jacks worked amazingly well. Probably not a smart thing to do but they sure worked great. If I did it again., I would clean the parts and reassemble. Removing the gearing is not a bad option but you will never be able to use the manual crank. This is not great advice but it does work.
This might sound confusing but when you open up the housing you will see what I mean.
