RV.Net Open Roads Forum: Travel Trailers: F 150, 3:55, 5.4 pulling 6300lb
 > F 150, 3:55, 5.4 pulling 6300lb
Page of 5
Terryallan
NC
Posted: 02/18/08 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
pacificnw wrote:
I agree, Ford is probably not concerned about this safety margin. But you ask a good question... where will they be when I am on the side of the road scratching my head wondering why that 9,000 pounds I am towing does not allow me to hold the speed limit going up the 8% grade over the mountain without hitting 5000 rpm, getting 14 mpg and smelling boiling transmission fluid?
Why do many think it is important to hold the speed limit up a 8% grade? Especially if it is 55 mph or more. Isn't that what the slow lanes are for? Seriously. The Trailertruck I drove. Which BTW was designed especially for towing, I mean. It had no other reason to be. Any way. It slowed on hills, any hills. Had 13 forward gears, and a 400 Kitty Cat. And it slowed on hills. Had to change gears often. If it does. Why should I expect my little truck to hold 55 towing up a 8% grade? I don't. I expect it to slow. I have the choice of what RPM to run. That is what the pedals are for. I choose 3000. When going up Black mountain. I hold it back to 3000 rpm, second gear, and 45 mph. And I still pass most of the other TTs 5ers, and all the trailertrucks. So I wonder. Why many feel it is so important to hold a high speed on a steep hill? Just extra work for the motor, For no good reason.
I also don't have a problem running 35 on the side mountain roads. Except of course where you have top slow for the curves. But then. The speedlimits on them are 35. Those are the ones that are steep. Interstates, are nothing compared to real mountain roads.
BTW. Any vehicle can break down on the side of the road. The last vehicle I saw broken in the mountains. Was a 2500 towing a 26'TT up 321 into Blowing Rock. I started to stop and tow it on up the hill. But didn't have my brake controler in the Expe at the time.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
pacificnw
Great Northwest
Posted: 02/18/08 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
It was a lot "tongue-in-cheek."
JLangton
Southeast Texas
Posted: 02/18/08 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
bobbyg123 wrote:
For me, it's either a 1/2 ton or a diesel. In my opinion, the biggest waste of cash is a 3/4 ton gasser.
Actual test results prove otherwise.
JL
2001 Lincoln Navigator 32V 5.4L V8/4R100 auto
1997 Ford Thunderbird LX 4.6L V8/4R70W auto
2005 F-250 Crewcab Lariat 3V 6.8L V10/Torqshift Auto
'06 Jayfeather 29Y-old TT
'08 Jayco Eagle 314BHDS-new TT
JLangton
Southeast Texas
Posted: 02/18/08 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
A wise man,and spoken well.
JL
graywolf67
Houston TX
Posted: 02/18/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
My TT is 5500# dry 6700# loaded and it does tow really well but you do have more wieght and the 3:55 gears which will make it sluggish going up hills. I don't have a need to climb hills as fast as some on this forum but boys will be boys. In the end it maybe alittle too much for your truck because of the reasons above. I remember my dad towing over some steep grades in the mountains, it was horrible and later we found out it fried the tranny (chevy Belair). The F150 is a great truck but like anything it has its limits even though some people think it can only tow a little red wagon
Ford 2006 F150 4x4 5.4l 3V 3.73 rear
Zinger ZT260RL.
www.rv-forums.org
Adam H
People's Republic of California
Posted: 02/18/08 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
JL
Exactly right. I'll be 10 minutes behind you at the end of the day.
Adam
mr61impala
Versailles Ky USA
Posted: 02/19/08 10:45am Link  |  Quote  |  Print  |  Notify Moderator
I must respectfully disagree.
There are many who like to load their truck bed (firewood, motorcycle, atv, golf cart, etc). Even though their TT's tongue weight falls well within the 1/2 ton catagory, the extra weight in the bed pushes the rear axle weight to the area in which a 3/4 ton truck is more desirable.
You can easily exceed your rear axle rating while staying well within your combined vehicle weight rating.
I often take my Honda Rancher with firewood, fuel, and extra water packed around it. I'm sure I have been over my rear axle weight limits on many occasions. This is why I will probably start looking for a 2500 gasser in a year or two. Of course, if the right deal comes along on something with a Cummins under the hood, who knows. If gas is still $.50/gal cheaper than diesel, maybe not
Dodge Ram 1500, 5.2 Magnum, 3.90 gears
Factory towing package
#12500 GCVW
Springdale 189FL, "The Baby Crib"
No worries!
rcknrbn
Brandon, MS
Posted: 02/19/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Gotta add my $.02
I've got a 2004 F150, 4x4, 3.55 rear end gears (factory tow package with 3.55 gears - go figure). TT is a 27' Fleetwood, weighs about 6,800lbs empty. First out of state trip was from MS to north GA. I thought I was going to smoke the tranny once I got into the mountains (hills) of north GA. Almost had it floored going up about a 7-8% grade for several miles, 2nd gear. Running about 40mph almost floorboarded. Knuckles were white!
Long story short.....I added a MagHytec finned aluminum differential cover, rear differential and transmission temperature guages. The rear differential temp. would average about 170-180 degrees in the flats pulling the trailer (about 140-150 while not towing). Pushed 210-220 in the hills.
About a year ago, re-geared to 4.10 gears (had to do front and rear being a 4x4). HUGE difference in towing ability. Still, not a F250 by any means but I don't do enough towing to justify buying a Superduty. Made a trip to the Smokies last summer, wouldn't hesitate to do it again with this setup.
Again, just my $.02
dodge guy
Chicago, western subs.
Posted: 02/19/08 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
It`s amazing what a simple gear change will do for towing ability!
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
smkettner
Posted: 02/19/08 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
You don't have to tow to enjoy a 3.55 to 4.10 gear swap.
Just getting around town is a lot more fun.
Page of 5
