Not a Clue
Southern Ca
I have a cabinet door that has pulled out all the screws so the holes are now to big for the screws to stay in.
Any suggestions as to what to use to fill in the holes so I can rethread the screws?
Thanks
Linda B.
2006 31' Fleetwood, TiogaSL - The Big Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
Traveling with Robin(friend),Liz(cockapoo)&Buddee(cavalier)
robsouth
Near Atlanta, GA
Bigger screws??
Dodge Ram 3500 Cummins Turbo Diesel Dually
1994 Terry 22U
1997 Regal 1900LSR
Charter GA'RVers member
"Great minds like a think"
slides
Piedmont of NC
Good carpenters glue and toothpicks into the holes after glue has set up sand or cut to make the surface level an reinstall the old screws.
03 Ford F-250 Super Duty Super Cab SB 4 x 4
6.0 Turbo Diesel 3.73 Gear
Torqshift Trans
'06 Rockwood 5er 8283SS
Use And Promote CB Channel 13
Terryallan
NC
slides wrote: Good carpenters glue and toothpicks into the holes after glue has set up sand or cut to make the surface level an reinstall the old screws.
This works. A variation of this. We didn't use toothpicks, cause we didn't have them. We just used little pieces of wood. Anyway. You wouldn't believe how much furniture is put together in this way. As good as new.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
camperbuds3
Pennsylvania, USA
Depending on the size of the original screw holes, drill them out a little larger in diameter, e.i. 1/8", 3/16" to the depth of the original holes. Purchase a wood dowel rod or wood pegs of the same diameter that you drill the holes to. Cut them to length so that they would be flush to the surface when forced into the holes. Put a little wood glue on them and hammer them into the holes. Allow the glue to dry, mark and drill a pilot hole for the original screws and remount the door.
usmohls2@yahoo.com
CA
As Slides said, Toothpicks or wooden match sticks glued into place.
fla.keys.
CT
camperbuds3 wrote: Depending on the size of the original screw holes, drill them out a little larger in diameter, e.i. 1/8", 3/16" to the depth of the original holes. Purchase a wood dowel rod or wood pegs of the same diameter that you drill the holes to. Cut them to length so that they would be flush to the surface when forced into the holes. Put a little wood glue on them and hammer them into the holes. Allow the glue to dry, mark and drill a pilot hole for the original screws and remount the door.
I agree with this method. I think that taking into consideration how much the rv moves, if the screws could pop out of the original framing, the tooth picks may not be enough. I would also add; use a hard wood dowel and a longer screw with a courser thread.
Mike , Amber , Sweet Baby James (and the dog )
2004 Chevy Silverado 2500 HD Ext Cab 6.0L 4x4
2008 Springdale 296-BH-SSR
Prodigy Brake Control, Timbren SES
DrawTite 1200 WDH, Dual Cam Sway Control
djevans
Tennessee
Done well, glued toothpicks hold. I either use toothpicks on light loads, then depending on the weight, hole enlargement, or strain. I too use all sorts, types, and sizes of dowels.
Don . . . near 36.171N 086.784W, TN near here
WA4ZFN
2003 Fleetwood Revolution 40C - Saturn VUE
350hp Cummins ISC
- - - P i c t u r e s - - -
I'm confused, WAIT! Maybe I'm not!
nny12972
NY
IMO....I agree with some of the patching options---personally, I'd use epoxy, but I'd find some matching machine screws....and put them all the way through the door and use washers on the back side...with "stop-nuts"....
Either you got a bum door or it's taking a lot of abuse for an '06...
J
Popsie
Livingston, TX, USA
Try Mr. Grip screw hole repair. These are metal mesh with sharp little blades. You stuff them in the hole, and when the screw goes in, it locks into the mesh while it pushes the blades very firmly into the wood.
They are available online and at Ace Hardware.
curious Bob - we fulltime with our Cairn Terrier, in 01 National Islander, and 00 Saturn LW2
