RV.Net Open Roads Forum: General RVing Issues: Fill screw holes
 > Fill screw holes
Hornet28BHDS
Parker, PA
Posted: 02/19/08 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Carpenters glue and appropriate sized dowel rods. Put them into the hole and then put the screws in them.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Deen
Vancouver, WA
Posted: 02/19/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
That's one of the reason we got rid of our '98 Santara. Had at least one screw strip out each time we used the rig. Paid extra in our DSDP's to get the real hardwood cabinets so this wouldn't happen. So far, with two different DSDP's not one screw has stripped out, in fact none have even come loose.
Oh yes, matchsticks and glue for the Santara.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Rough2000
Arkansas
Posted: 02/19/08 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
This is the best fix that I have found, and with my 06 Prowler I have had several. It's almost like some of the wood is as light as balsa wood.
2006 Dodge Ram Mega Cab w/Cummin's
2009 Jayco Designer 34 RLQS
bobsallyh
Livingston, Tx.
Posted: 02/19/08 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
If you can get to the back of the area where a drilled hole thru the hole that is there now, use a tee-nut with a matching machine screw for the hinge. If you can't get behind the area, get wood inserts( metal cylinders with threads on the inside and reverse threads on the outside). Drill hole the size specified for cylinder and turn in, then use machine screw that matches the hinge. There are two types that I have seen, one for wood use and another for particle board. I just recently I have used the tee-nut set up for a cabinet door with three hinges.
Rick From Sequim
Sequim, WA
Posted: 02/19/08 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
Kinda depends on where the holes are. If they're in solid wood, like a two by two, toothpicks and glue might hold for a while. If the holes are in your 1/8 inch thick wall panels, you need to consider some sort of hollow wall anchor (like mollybolts, etc.)
Rick
& wife Loie & Kodi Dog (blk male std poodle)
1995 F-250 460 Banks (wow!) & 2005 25' Bigfoot RQ
mobeewan
Hampton, Va
Posted: 02/20/08 03:20am Link  |  Quote  |  Print  |  Notify Moderator
camperbuds3 wrote:
Depending on the size of the original screw holes, drill them out a little larger in diameter, e.i. 1/8", 3/16" to the depth of the original holes. Purchase a wood dowel rod or wood pegs of the same diameter that you drill the holes to. Cut them to length so that they would be flush to the surface when forced into the holes. Put a little wood glue on them and hammer them into the holes. Allow the glue to dry, mark and drill a pilot hole for the original screws and remount the door.
I used this method to remount the striker plate to the door jamb for my front door lock. It is as good as new.
SSport
Edison, NJ/Stroudsburg, PA
Posted: 02/20/08 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Recently the screws on my house storm door ripped out of the door frame. I went to Home Depot and picked up Elmer's Wood Filler in a white bottle. It worked AWESOME and dried quickly. I would definitely recommend it.
Not a Clue
Southern Ca
Posted: 02/20/08 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the great ideas, I have limited space to work with. The door is under the bench where the table is. There isn't a whole lot of customizing I can do with the space wood area available.
I might try the filler first.
Thanks again for all your responses.
Linda B.
2009 29' Fleetwood, Fiesta V10 - The Big Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
Traveling with Robin(friend),Liz(cockapoo)&Buddee(cavalier)
Cruzette
Santa Cruz, CA
Posted: 02/20/08 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Mix some sawdust with some Elmer's glue and pack it into the hole. Allow to dry several hours before screwing the cabinet door back in place.
Cruzette
SAL Rally Queen
13 Rallies & numerous Gatherings attended so far!
Judy & Ray
Boomer & Petie Pie (2 Doxies)
F-350 Powerstroke
29' Yellowstone Capri, by Gulfstream
w/ 2 slides
ib516
Up here!
Posted: 02/20/08 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Golf tees covered in wood glue. Tap them in with a hammer, let dry, break or cut off what sticks out. Done.
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen (still going)
Collision Reconstructionist
ScanGauge2
 > Fill screw holes
