RV.Net Open Roads Forum: Truck Campers: Adding an XM antenna solution needed.
 > Adding an XM antenna solution needed.
RichieC
Gig Harbor, WA, USA
Posted: 02/20/08 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone added a XM antenna / receiver to their truck?
We have XM radio on the car and want to add a reciever and antenna to the truck camper.
The camper cabover will block reception to the antenna which would normally be mounted above the cab.
Any solution ideas welcome.
Eagle Cap Owners Group . . .
Spott
48197
Posted: 02/20/08 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Hope this helps link
Me - Kim - Spot
2005 204 ssi on the water - TCM article
Moomba2002
Sebastopol, CA
Posted: 02/20/08 10:13am Link  |  Quote  |  Print  |  Notify Moderator
I have XM and I mounted a small metal tab on the camper gutter and then when the camper goes on just remove from the cab and place on the camper, works great. The antenna has a magnetic base and the cord has quite a reach. If possible definitely go with a integrated XM box if possible as the modulators do not work very well to hold the signal.
1999 Ford F350 DRW 4X4 PSD 6spd.
Banks Stinger Package
Fords upgraded Air Intake System
ExtremeAire 150 PSI 100% Duty Cyle on board air w/4gal. tank
Air Bags & Rancho 9000's
2003 Arctic Fox 1150 loaded except solor
SugarHillCTD
Sugar Hill, NH, USA
Posted: 02/20/08 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Stick a magnetic XM antenna out at the front edge of the hood. Mine stays there whether the TC is on or off.
But be aware that if you are in the northern states or Canada, when you travel in a northbound direction, the TC might occasionally still block the signal especially when driving under trees with leaves on the branches. Otherwise it works fine.
John
2006 Dodge Ram 2500 QC/LB 4x4 Cummins/6 speed- GONE
2006 Northstar 850SC- GONE too
1993 BMW K1100RS a.k.a. Hades, the new "RV"
2007 Kaw 250R
Best friend/DW on the passenger seat
flakjacket
Fremont, CA
Posted: 02/20/08 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Run the magnetic antenna through the firewall under the hood and place it on the front edge of the hood on the drivers or passenger side. No problems in 3 years with the camper blocking the signal.
2005 Silverado 3500 LT, CC DRW 4WD D/A, Ride-Rites, Rancho 9000, Line-X, XM Radio (That I can't live without)
2007 Lance 1181, Fastguns
Fire Chief 8101
Bellingham,WA
Posted: 02/20/08 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a after market antenna on an "L" bracket on the hood lid way out front. Works great. did the same thing with my GPS antenna.
Mexray
Stockton, Ca
Posted: 02/20/08 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
I too mounted a magnetic 'puck' external antenna on the hood, up forward, ran the cable on the underside of the hood and made a loop back where the hood opens in front of the windshield, thru the firewall and into the cab.
I use a delco xm receiver and mounded one of the base mounts on the dash...and another base mount inside the camper with another antenna mounted on the roof top...then I just switch the radio unit from the cab to the camper when I want.
Both base mounts are hooked into their respective stereo/radios in the cab and inside the camper. Our Lance didn't have a stereo unit in it, and our Ford had an older radio in the cab...so I bought two identical Sony stereo/radio units that have an 'AUX' option for the xm radio...works great!
We also have a Garmin GPS unit, and I mounted it's external antenna up front on the hood right next to the xm radio's antenna. The GPS would work with out the external antenna, I believe, but it has a 'clearer' view of the sky with the magnetic antenna up on the front of the hood, and so probably starts up quicker, and may be more accurate being able to acquire more sat's in that way. Works for us!
2000 Lance 1010 atop 1999 Ford F-350 4x4
5.4L, Supercab, XM Radio, SWR, 325/65R18 ProComp XAT's
4" lift, DynaTrac Hub Conversion, 4.56 gears
Rear Detroit TruTrac, SuperSprings, Warn hubs.
Any time is 'Baja Time'
dennis1
Seattle, WA
Posted: 02/20/08 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
I mounted one on top of the camper in the rear passenger side. Ran cable from there under the camper and thur the cab the to the XM receiver. It's in the back so if I need extra clearance from under trees I can reach up to the antenna and release the mount and it will lay flat to the roof. Works great no loss of signal even going to Mt Rainier via 410 and over to Yakima. I bought the XM Marine antenna.
My new DRW and camper on the truck the first time.
kapitman
Pine Junction, CO
Posted: 02/21/08 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Based on suggestions I received here, I purchased a Delphi XM receiver and installed it in my truck with the antenna magetically attached to the front of the hood. I purchased a separate cradle and I can move the receiver from the truck to the stereo in the camper when we set up and receive XM signals there. We use the XM almost exclusively now, and do not listen to CDs very often anymore.
Mexray
Stockton, Ca
Posted: 02/22/08 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
Kapitman...that's the exact same set-up I installed. We also hardly play any CD's either...we do like Jimmy Buffett, and I've converted most of his tunes to mp3 format and put one one CD!
We do haul around some DVD movies, though. I've put our DVD disc's in holders to cut down on the bulk. I use a program called 'Film Tracker' to catalog them and print out a list.
We've got a friend that has a portable digital DVD projector he hauls along when we go camping together...we hang up a white canvas, and have our own 'drive in' movies for our families!
