RV.Net Open Roads Forum: Towing: Durango vs Tahoe
Search only in Towing
Open Roads Forum  >  Towing
 > Durango vs Tahoe
DnDS
Rosamond
Posted: 02/21/08 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2003 Tahoe and pull a 30TT with no problem. The TT is about 7000#'s. Our Tahoe has a 5.3L with a 4.10 rear end and the tow package, you will want to look for that if you look for a Tahoe or Yukon. Good luck in you decision.
Dan & Darcelle
2003 Chevy Tahoe
2006 Fleetwood Yukon 290BHS
2 Kids
2 Dogs
havedreamwilltravel
Posted: 02/24/08 12:27am Link  |  Quote  |  Print  |  Notify Moderator
We pull with a shorty Yukon. Although it's a 2007 with a bigger engine - the wheelbase is the same so i'll comment on that.
Our trailer is 29' from ball to bumper. We have experienced zero sway issues with our set up and we have towed through some major winds. We get little to no push/pull from passing semi's with our set up.
"with our set up" are the key words to remember. You can have the best truck, trailer and hitch but if it's not set up properly you can still get sway and have a horrible towing experience. Getting the proper equipment and setting it up PROPERLY is the key.
With either vehicle - the Durango or the Tahoe - you will need to get away from your simple friction bar type hitch and invest in a better WD w/sway control hitch. There are 2 more popular one's here - that is the Equalizer (brand name) and the Reese Dual Cam. Both have weight distribution and anti-sway bars. The Equalizer is an all in one hitch - everything comes with the hitch. Easy to set up and hitch and unhitch - it's what we use and are very happy with it and because we are set up PROPERLY we have zero towing issues regarding sway. The Reese Dual Cam is another one that is highly regarded - but I cannot comment about it since I have not used it.
If money is not an object, looking into the Hensley-Arrow hitch.
We like our Yukon (sister car to the Tahoe) and we also own a 2005 Suburban w/4.10's that we bought used. Like them both and both pull the trailer just fine.
Side note: If your buying a used Tahoe/Yukon or Suburban/yukon XL you will want to change out your receiver. GM has had some issues with the round tube crossbar receiver and bad welds and some hitch failures. This is an easy fix to remove and replace - less than $200.00 to do.
2007 GMC Yukon Denali - 6.2L 380hp/417ft-lbs,0-60 in 6.2 seconds
2007 Jayco Jayflight 27BH
Equalizer Hitch, Prodigy Brake Control
Our Truck and Trailer
Easy Trailer Mods-NEW pics added 4/10/08
Visited a lot of states, haven't camped in many...yet.
atvanish
Central PA
Posted: 02/25/08 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advise. I agree - I think I need a better hitch setup and either would be fine.
2004 Dodge Durango Limited, 4x4 Hemi
2005 Dutchman Lite 27B
atvanish
Central PA
Posted: 03/14/08 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Just a quick update - thanks for the info and I just got a 2004 Durango 4x4 Limited, 5.7l, 3.55's w/ 40K miles. Can't wait to tow with it!
00zx6r
Ca
Posted: 03/14/08 10:07am Link  |  Quote  |  Print  |  Notify Moderator
atvanish
Congrat for your new Dodge Durango Limited.
2001 E450 Fourwinds Majestic 26
2004 Dodge Durango Limited Hemi 4x4 LO
2005 18' Haulmark enclosed trailer
2005 Honda CBR1000RR Resol
2004 Honda CBR1000RR Silver
2002 Honda CR250
2005 Honda 250 Recon ES
2002 Honda TRX90
2000 Kawasaki KX 250
DnDS
Rosamond
Posted: 03/14/08 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Congratulations on the new Drango. Please let us know how it tows.
Loopy
Western Pennsylvania
Posted: 03/14/08 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
hookie wrote:
00zx6r wrote:
Atvanish
Just an FYI Tahoe/Yukon doesn't offer 3rd row seat unless you go with Suburban/Yukon XL.
Here is a towing info for those vehicles
2005 Tahoe
2005 Suburban 1500 and 2500
2005 Dodge Durango
This is NOT true. In fact, just try to find a Tahoe WITHOUT a third seat!
I can go look in my driveway, how about that?
You might want to correct your statement to say, any Tahoe from the year 2000 and newer could, and most likely will, have a third row seat.
Bryan , Jess, and our Parsons Russell Terrier, Melvin
1999 Chevrolet Tahoe 4D 4WD 5.7L 3.73" Rear End
Reese Strait-Line Dual Cam Weight Distribution Hitch
Tekonsha P3 Brake Controller
2008 Jayco Jay Flight G2 20BH and Mods
Radartech
LI. New York
Posted: 03/14/08 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
Into snowmobileing and towing a 5000 lb load 4 place inclosed trailer. Before we got the 2500HD we had both 99 Durango 5.7 and 03 yukon Denali 6.0. No competion The yukon was better in every way including Milage and Power and les sway.
06 Chevy CC SB D/A
08 362 Fuzion
03 1800 VTX
07 1100 V-STAR her's
00zx6r
Ca
Posted: 03/14/08 11:55pm Link  |  Quote  |  Print  |  Notify Moderator
I am not sure about your 99 Dodge Durango but since 2004 Dodge released a new re-designed Dodge Durango improved alot compared to the previous models. Here is a review of Top 10 vehicles towing
eurohazard
Travis AFB, CA
Posted: 03/16/08 03:13am Link  |  Quote  |  Print  |  Notify Moderator
1999 Dodge Durangos didn't have a 5.7 V8. No disagreeing that a 4 year older, bigger, more powerful Denali was a better TV than the old Durango......but the newer ones might be a different story.
-2006 Nissan Armada LE 4x4
-2007 Coachmen 19FLB SE
-2007 Regal 1900 w/ 4.3 EFI Volvo
Supercharged wrote:
4-in-a-fiver and my statments make the same amount of since.
 > Durango vs Tahoe
